NAV and 6 disk changer in a Silverado
:D I just completed the lux conversion this morning.  Everything went fine, the only problem is that my driver side and rear speakers have no sound, only the front passenger side.  All else is good, steering wheel controls etc....   Has any one else had this problem.  The vehicle is a 2005 Chevy Crew Cab, 1500.  I am going to check to see if i pluged in the proper wires for the outputs, that is all i can think of right now.  Any help would be greatly appreciated. :D
I just did the upgrade and I too have the same problem...its killing me...I have checked all my outputs and have double checked against the diagrams from this post...everything works lovely but only having 1 speaker is killing me..I hope that you solved this problem and would share with me....
thx
Bigg Kev
It sounds like you need to program the amp. Where did you get the amp? If it's new, you will only get sound out of the front passenger speaker.
Hmmm....I bought it on Ebay. I was told itwas pulled from a 2004 denali for an after market install.....at least I have a starting point. I will need to look through this thread and find the steps for programming the amp.....is there anything I need to be aware of when I visit the dealer.( which was really cool about the tech2 procedure..even though he could not believe I had hooked the system up myself..LOL
Bigg Kev
p.s. thanks for the quick response...I have been hiding my truck from my wife until I finish this mod.....so I have been riding in her Jetta all weekend....Its like riding in a Yugo with a spoiler kit......need my sounds back.....LOL
I installed the ext 6 cd changer...everything working except the speaker issue described above. I plan to go to the dealer saturday hopefully its all I need. I hate to order another amp if this one does not work...
UPDATE!!!
Went to the dealer and had the amp recalibrated as per the tech2 instructions posted earlier........Everything is working......I would like to thank everyone for the hard work put in before I attempted this install.....The sound was well worth it....
  • Replies 923
I have a 2005 Envoy with a Bose Audio system and most of the extras like Onstar, XM, Steering wheel controls rear controlls and DVD entertainment package.
I have read through this very long forum becuase I want to swap out my head unit for the navigation touch screen unit. The original numbers people were saying to buy was 10377287 but now all I see is just 15800001 or 15800000. Can Someone please tell me which models will work for my truck. Also how do I know if mine is the Lux or non Lux model.
Does the DVD have to be in the whole time for the navigation to work?
Thanks for you help
Thanks for you help
<{POST_SNAPBACK}>
Here is a REAL good source of all this info compressed down to just data:
(Note: part numbers are listed here to)
TNR INSTALL INFO
Yes, the nav dvd needs to be in to be navigating. If you want to play cds at same time, you need add a cd changer.
dave
Thanks for you help
<{POST_SNAPBACK}>
TNR INSTALL INFO
dave
<{POST_SNAPBACK}>
How do I know if mine is the lux on none lux model
i have a non-lux model, is the XM Info button suppose to do something? i have the XM Info Timeout set to OFF and i have never seen this button available. i do have XM..
nothing really in the manual
thanks
Thanks for you help
<{POST_SNAPBACK}>
TNR INSTALL INFO
dave
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
Look in the glove box, if you find a code that says Y91 or Y92, you have the LUX package. If you see U6C (I think) you have the non-LUX package. If I were to bet, you don't have the LUX package. It's only seen on the Escalades and Denalis.
Thanks for you help
<{POST_SNAPBACK}>
TNR INSTALL INFO
dave
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
The Bose lux (y91) (or BOse nonlux - UQ7) model is designated by the code in your glove box. spend some time reading here to find out the codes and what they mean...there is a RPO code guide in the nav bar of this site.
Also find pictures of the lux amp on the link I posted B4.
dave
Does anyone know if I can install 2 factory RSE units? I installed one in the back and I want to rig one up with the DVD drive in the console and the LCD in the visor. I don't know if the headunit (NAV) will recognize 2 RSEs.
  • 3 weeks later...
Hi Linda,
I have an 06 Tahoe with the non-bose radio/cd/8spkr system. I would like to upgrade to the bose-lux system. I saw your thread, which discusses a different project, but I'm wondering if you can shed some light on my goals. Below is a link to my thread. Thanks,
Dean
http://www.gm-trucks.com/forums/index.php?...07entry387207
the BOSE system is a MUST! you have to have BOSE audio system from the get go. If not...you will spend WAY to much for the retrofit.
  • 3 weeks later...
I just installed the lux TNR on my 03 burb and installed an Escalade console that has the lux amp. Everything is perfect except only the right front speaker works. The TNR, console and amp are all brand new, and I saw something on this post that says a new amp will only play right front until it's programmed. That's fine, but I had another used amp out of an Escalade SUV, so I stuck it in. I then got left and right audio, but only front -- nothing from the rear speakers. Would it need programming too? I've checked and double-checked my wiring but can't see anything wrong. Also, the audio works perfect from the headphone jacks in the rear of the console. But the "seek" and "program" controls back there do not work. My steering wheel controls work great.
Thanks!
Glenn
I found my problem. The Y91 option has the rear speakers wired differently than the non-Y91. And I had my new amp programmed for $20 by the dealer, and everything works perfect now!
-G
PS: If anybody wants to install an Escalade console in a vehicle without lux audio, it allows you to use the lux amp without so much harness rewiring (your only have to re-wire the rear speakers and feed the amp with the Class II data). The wiring is mostly already correct for "lux" from the big connector (C306) under the console cupholder back to the amp.
I sure could use some help.. I have a 2003 Envoy non lux and want to install a 2004 non lux navigation HU. I called JP and got a $25 wire kit, but he wasn't sure it would all work. Any advice? Anything else I need to plug it in?
  • 1 month later...
correct Mike, that harness is the "SLAVE" harness cable thats the same for all GM slave devices since 1998-2002, so we have to modify it a bit to work for us.  What you do is plug the one end into your slave device (6 cd changer) then use the fancy "PINOUT" document that I made, to hook the other end to the head unit.  The other end needs to have the pins pulled out of the connector and inserted in their correct spots in the 12 way harness on the back of your head unit.  The 24 way harness is your main, that includes speaker outs, data bus, voltage, etc.  The 12 way harness is your "AUX" input, its used for OnStar, slave devices, and i think thats where XM would tie in also, but im not sure about that one yet.  Im still looking for info on the XM hookup.  My truck being a Silverado, does not even have an option from the factory for a 6 disk changer in the console.  So NO, i had no harness for the changer, just was lucky enough to fall in good with a few guys who gave me pinouts and schematics so i could create my own harness.
Anyone feel like doing a step-by-step, detailed with pictures install guide for those of us who are too dumb to know what half the stuff you are talking about is? :)
Id really like to change my stock system as it really doesn't sound that great. I just don't know which way to go. This mod looks really cool. I just have to find me a Installing a NAV unit and nice sound system for Dummies book :cheers:
    whenindoubtuseahammer
  • Who's Online   1 Member, 0 Anonymous, 505 Guests (See full list)
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
