NAV and 6 disk changer in a Silverado
Just wanted to thank everybody in this forum for the valuable information about this NAV & CD changer install. I finally did it and I'm so happy with the results. At the beggining I was worried about what some of the members here said about the soud quality of the Non-Lux Nav. system but I can honestly say the from my experience, the sound quality is much better with the Non-Lux Nav system than the original radio cassette cd. I bought my system brand new from Jason at JP Customs who is a real pleasure to deal with. He made me feel like I've known him for years just talking to him over the phone. He really made my experience of buying from JP Customs a pleasurable experience. Also the reasons I decided to buy from JP Customs are:
1- The units are brendnew so I don't have to go to the dealer.
2- The warranty they give is uncomparable. 3Yrs/ 3600 miles if the truck is new or the remaining of the GM warranty Or 1 year if you passed the warranty period whichever is longer.
3- If you compare the price for a new unit from gmpartsdirect you'll find out that the difference in price don't worth it especially if you read the fine prints on gmparts direct, it'll tell you that there is no warranty at all on the units they sell for the upgrade purposes ant it might even void your warranty.
At the end, I am really happy with this new upgrade. Definately woth the money.
I think I forgot to mention that I did the 6 cd slot changer too. Thanks to everybody.
  • Replies 923
Have Bose Lux amp for sale out of a Hummer. Part #15199884 if anyone interested. $200 shipped in the lower 48.
<{POST_SNAPBACK}>
Sold it.
Okay first post here. Thanks everybody for all the info. I have successfully removed my stock 6 disc radio with an inr nav unit (easy). I decided to keep the non-lux amp. I'm a rookie at this stuff and it seemed the easiest path of least resistance. Now I would like to add a 6 disc cd changer in the pocket on the console. I purchased a changer that is appropriate for my model year - 2004. The harness wiring appears to be the most difficult part best I can tell. My question is this - can the part number GM12-MFF eliminate the need to splice and cut. It looks like it is simply a y harness for the 12 pin HU input. Has anybody tried this? Please let me know what u think. Thanks!
link:
http://www.radiosandmore.com/prod_detail.asp?pn=GM12-MFF
link:
<{POST_SNAPBACK}>
The GM12-MFF will only provide you with the audio inputs, you will still need to splice into the 24 pin connector or wires to get the databus signal, 12 volt positive, and a ground. So in others words the GM12-MFF will only save you the trouble of splicing the 3 audio wires, the left pos., right pos., and the common.
link:
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
Thanks a lot for the quick response. That was what I had thought although hoped that maybe something had come along that might be plug and play. Thanks again.
Ok. here is the situation. I have a 2003 ENVOY SLT with Bose 6-disc in-dash CD, Onstar, RSA, Steering wheel controls, etc. I do not have Y91 (which I don't believe applies to Envoy/TB's) listed but do have UQA option listed. My Bose HU has the "Spacious, Driver, Rear, Passenger" sound field options that work well. This led me to believe that I have the Lux-amp.
So, I upgraded to a LUX-Nav Part #10377531 and the USA-Spec External 6-disc CD Changer. Everything seems to works fine...steering wheel controls, nav, RSA, On-star. Sound is OK (a little lacking in the bass dep't) but the"Spacious, Passenger, Rear" sound fields don't seem to do anything. Only the "Driver" sound field changes the sound quality. This led me to believe that I don't have the Lux-amp. But everything else works fine. So I was the told that the Envoys/TB's recieved a "Lux-Like" amp which uses the Class II data bus for volume and balance/fader control much in the same way a GMT-800 LUX amp does, but, it doesnt have any onboard DSP for creating the different sound fields. Its more or less a "bastardized" amp setup kinda think of it as a "wanna-be" Lux amp. I then tore apart my rear cargo area to find this elusive amp. It is a Bose amp but looks nothing like the pictures of the Non-Lux or Lux amps I've seen on this forum. The part # is 15187195. It has 3 connectors not 2.
A search on gmpartsdirect.com revealed that it's an expensive little bugger!!!
530$ from GM Parts Direct!! 960$ GM List price!!!!.
I'm wondering if I can just swap out this amp with a 3-connector Lux-amp. Would it just be a matter of simply swapping and connecting the 3-connectors or would I have to do any tinkering? The Bose Audio Pilot micophone for Auto Volume Control doesn't really concern me, as long as I could improve the sound quality I'm getting. Don't get me wrong...the quality is good...but the bass is a little lacking and I would love to have access to the DSP sound fields (Especially the "Spacious" mode).
Any info would be greatly appreciated. :seeya:
Not sure swapping the amp will work, but if you decide to try a NON-LUX NAV Unit I'll buy your LUX one for my Escalade. Is it the TNR? How much would you want for it? Email me @ [email protected]
Any info would be greatly appreciated. :cool:
I don't think that a non-lux Nav would work in my truck.
One question... do all Lux Amps have 3-connectors, and do all Non-Lux Amps have 2-connectors?
Thanks again in advance. :D
UQ7 is the Bose speaker system, you could have that with the lux or the non-lux amp.
If you don't see Y91 or Y92 then you don't have the lux amp.
Thanks a lot. :cheers: The unit is 15229287 and from other posts I assume this will work. Just want to make sure. You have been extemley helpful
After all this time I have finally purchased a nav unit from e-bay. It is a new 2006 model for a non lux application and it came complete with head unit, 4.1 dvd, and antenna. I installed it and everything seems to work fine except for one small problem. The indicator on the gps screen for the vehicle does not point in the direction the vehichle is traveling. It is showing the correct position on the road but is kind of jerky because I have not figured out the vss wire yet. Can anyone help me on this? Thanks
you do need the vss wire I have seen where many people said you did not need it but it works very eractic without it, I would put a switch in the wire so your passenger can program the TNR while you are moving & if you trvel very far with the switch in the open position it will take some time before the TNR corrects itself as to your position, you need to add the VSS wire to the HU 12 pin connector in the "E" position, this should be empty, you can pick up VSS at the gauge cluster connector in the A4 position and it should be a dark green wire with white tracer, the terminal you need for the E position in the 12 pin connector is a gm part # 12089649, this should get you going.
good luck Bob
I am about to add Nav to my recently purchased 2006 Z71 Crew Cab, and the in-dash slot cd changer, wondering if anyone has directions/pictures on how to modify the console pocket to make the 6 disc slot loading cd player fit?
Thanks.
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,533 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
