NAV and 6 disk changer in a Silverado
mrbossman, yes it can, and yes it will.
<{POST_SNAPBACK}>
If it is possible to copy the disc, I would assume you must use a dual layer dvd, since the disc is over 7GB? Has anyone personally done this? Also, would anyone happen to know where one might be able to find an .iso of the disc? This is, of course, for backup purposes only, as some of us may have scratched the original DVD, yet we still own the copyright, and just need to replace the data.
<{POST_SNAPBACK}>
There is a way to put a functional 3.0 nav disc onto a single-layer disc, but the prerequisite is the same as that for copying it onto a dual-layer disc--you need an existing 3.0 disc/image in order to do either one.
FWIW--a complete ISO of the 3.0 is around 6.5 GB IIRC; I guess you can search the usual download sites but I'd be surprised if you're able to find one there.
I plead the 5th as to admitting whether I've personally made a copy of the 3.0 disc...but as mentioned earlier, the ISO is over 6 GB (hint-hint)... ;)
  • Replies 923
I just put in a 15230099 Touch screen nav unit into my 2005 Envoy Denali and i'm not getting any sound including onstar sound/vehicle sounds, anyone have any idea what the problem could be? I took it and got it unlocked but it has no audio.
My 6 disk changers model is 10359565
Is that a lux or non lux? I'm starting to think my Envoy Denali is non lux and I got the lux touchscreen
I would agree with Linda, Y91 doesn't always guarantee that the system is a lux version. althought it is supossed to be that way but GM does take some short cuts.
Guest 007FL
Hello
PAC, PIE, BLITZSAFE, SOUNDGATE  ????
Which Interface(S) do you use to incorporate a backup camera and DVD Changer into your factory Nav System? Can you control the changer with the wheel controls ?
Changers like Sony 10 Disc CD DVD DVX-100 ,PANASONIC CX-DH801U 8 DISC or Alpine DHA S680 dvd/mp3/cd changer.
I have read about the backup camera, my real concerns are incorporating and controlling the DVD changer, video and sound. I want to use the GM Nav HU as my monitor. I have not started buying parts yet I need some feed back. I am researching and talking to everyone I can. I have a 2005 Avalanche 1500 with the Bose none y91 system, no nav yet.
Here is the best option I have found for the backup camera/external video input to a Nav System.  They even have a video showing how to install their adapter.  looks very easy.
http://www.audioandvideointerfaces.com/home.htm
Thanks
MrBossman
Oh thanks a LOT!!! Now there is just ONE MORE THING I can't go without! HONEY, WHERE'S THE CHECKBOOK?
:chevy:
Well I pulled out the lux amp and installed the original premium amp and everything is back up. I'm not going to mess with it anymore and decided to just forget about it. I guess now I have a 6-disc unit that I didn't have before so I got half the upgrade! I just wish the dealer wouldn't have messed up the headunit and this trouble could have been avoided. I know it may still be possible to get this to work, but not with the dealer here.
I'm selling the lux amp, BTW.
http://dieselplace.com/forum/showthread.ph...6113#post616113
Thanks for everyone's help!
<{POST_SNAPBACK}>
I posted your link on another forum where I posted my Lux nav unit for sale, alot of folks were wondering where to get the LUX amp at.
Just wanted to thank all the posters for their info. I successfully installed the tnr into my 2005 gmc 3500 crewcab. As an aside note when it was all said and done the vss wire was already in the truck factory.
Aaron
PS Firetiger, your amp worked perfect for me, only problem I have is that the lowest volume isnt all that low
Just wanted to thsnk sll the posters for thier info. I successfully installe the tnr into my 2005 gmc 3500 crewcab. As an aside not when it was all said and done the vss wire was already in the truck factory.
Aaron
<{POST_SNAPBACK}>
I have a lux amp, it didnt work in my truck when programmed, but was told it would work in other vehicles besides the silverados, such as tahoes, yukons, denalis, etc. Its collecting dust here. I had to buy one that came out of a wrecked sierra denali, that already worked, and it worked great in mine. I would do a money back if it didnt work.
Aaron
<{POST_SNAPBACK}>
Glad to hear it worked well for you. Can't tell you anything about the volume. When I had it working in my truck (with the theftlock temporarily disabled), I didn't have it down low enough to notice any problem as I was trying it out and listening to different soundfields, etc.
    whenindoubtuseahammer
  • Who's Online   1 Member, 0 Anonymous, 295 Guests (See full list)
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
