NAV and 6 disk changer in a Silverado
  • Replies 923
mrbossman, yes it can, and yes it will.
Firetiger, i misunderstood your question, sorry. So you have a 6 disk headunit that was of the premium variety. Now after the theftlock removal, you have no sound? If this is correct, i still stand by my first comment. I still think the AMP took a flash it wasnt supposed to. From what i remember, the LUX 6 disk has the same "pin-out" at the head unit harness as the non-lux, thus, all the programming should be in the AMP. I will confess i am not up to speed on these head units and how they operate. The only reason i say this is because the NAV units are not flashable, you cant take a non-lux NAV and make it a LUX one by just flashing it. Not at the dealership with the TECH II anyhow. So i would say get another AMP, and hook it up and see what you get. I dont know if they make these 6 disk headunits in both the lux and non-lux variety, i didnt think they did.
Yes, unfortunately they did make the 6-disc HU's in both lux and non-lux. The non-lux are offered in the Silverados and now that's basically what I have after they messed it up. It went into the dealer as a lux and came out with non-lux. Nice, eh?
If I knew they were going to hose up the lux 6-disc and downgrade it to the premium, I could have just bought a cheapo premium 6-disc as that's where I stand right now. That's pretty much the entire reason for getting the H2 6-disc so you don't have to monkey around with getting it programmed to the lux version and you're a step ahead.
I still have the door chimes so I'm assuming the amp is OK. But until I get the HU reprogrammed to lux, I won't know for sure.
Maybe it is the case that it all has to do with the amp? I've heard otherwise also, so it's a mystery right now to me.
I'd be nice to try a different lux amp, but I'm not going to throw another $100 down the tubes on this BS. What started out as a low-budget upgrade has turned into spittin' into the wind. Until I get some concrete answers on what can be done, I'm going to just rip it out and let it collect dust.
I was going to buy a .45 Ruger but decided to try this project first. Looks like I'll have a couple of items for target practice when I get that gun............
Thanks again! If you have any other ideas, please let me know.
Installed my TNR into a 2005 Silverado LT tonight ... :cheers:
Now I have to decide what other audio gems I want. This 6 disk changer deal looks sweet, but I am also contemplating a set of AUX RCA jacks for SIRIUS in additon to XM and an MP3 player.
Hmmmmm.... decisions, decision, decision. Thanks for all the great information on this thread. It is a daydreamers paridise!!
:flag::cheers::D
I just bought http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=7982720650 as my NAV unit. the part # is 15230099. Anyone know the part # for the aentenna? Does the NAV unit have to be installed before they program it? Do they pull it out of the vehicle when they program it? Whats the newest version of the mapdisc?
<{POST_SNAPBACK}>
Based on my research over the past few days:
3.0 on the disc
15135178 is the GPS antenna
all on e-bay
if i already have the bose XM radio in my 2500 hd what do i need to get???
Poonis, shoot me an E-mail this afternoon.  I get off of work arount 5-6pm EST.  I will send you some documents that will make the hook-up understandable.  Send the E-mail to:
[email protected]
Also poonis, you will need to solder three wires into the Hu harness, it will only take you a second to do.  The three wires we will need to solder too are:
1. + voltage (bigger of the two orange wires)
2. ground    (blk/wht)
3. class II data line  (smaller of the two orange wires)
Make sure you dont cut any wires off the new harness you got.  We will be removing the connector from one end, but we will be just removing the pins from the connector, not cutting them out.  The pins that we remove from one end of the connecter will slide right into the 12 pin harness.
I will give you some better info and schematics later tonight.
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
cbiggers, the antenna is part no. 15135178 (about $50 at GM Parts Direct)
the Nav unit has to be installed to remove the theftloc. The newest version is still ver. 3.0
The nav HU you bought is a lux model, are you installing this in a vehicle with the lux system? Check your glove box sticker for a code Y91 or Y92, if you have either one of those codes the nav unit will work in your vehicle. If you don't have one of those codes then you have a non-lux system and you will need the change the Bose amp to a lux amp and do the required wiring changes before it will work.
<{POST_SNAPBACK}>
Firetiger,
this may not be want you want to hear but this is what I found out.
the non nav headunits can be used in both a lux or premium system. The BCM and service programming for each vehicle decide how the headunit is configured. Since the service program in your truck is setup up with the non-lux program the headunit is told that that is what it is going to be. No matter what headunit (non-nav)you stick in your truck it is always going to end up being a non-lux. The nav headunit are made specifically either a lux or non-lux. The nav units are not supported by service programming and that means that they do not rely on the BCM to decide what setup they run in. That is why so many of us have been able to install them in a vehicle that did not come with or even have the option of a lux system.
You can still use that H2 lux 6 disc player in your truck, but you will need to put the non-lux amp back in and undo the wiring changes. Your theftloc is allready removed and the headunit is allready changed to a non-lux so there is no need for any further dealer visits. If you decide to not use it and sell it, it can still be sold as a lux or non-lux unit because whoever installs it will have to have the theftloc removed and it will relearn a new VIN and also relearn the configuration for the vehicle it gets installed in.
It has been done in other trucks, so I don't believe we have come to the end of this yet. It sure worked good in my truck before the Theftloc was removed!!
Hello
PAC, PIE, BLITZSAFE, SOUNDGATE ????
Which Interface(S) do you use to incorporate a backup camera and DVD Changer into your factory Nav System? Can you control the changer with the wheel controls ?
Changers like Sony 10 Disc CD DVD DVX-100 ,PANASONIC CX-DH801U 8 DISC or Alpine DHA S680 dvd/mp3/cd changer.
I have read about the backup camera, my real concerns are incorporating and controlling the DVD changer, video and sound. I want to use the GM Nav HU as my monitor. I have not started buying parts yet I need some feed back. I am researching and talking to everyone I can. I have a 2005 Avalanche 1500 with the Bose none y91 system, no nav yet.
Thanks
MrBossman
<{POST_SNAPBACK}>
my 2005 Envoy Denali has the Y91 option on the sticker in the glove box. So i'm %99 sure its going to work, You never really know though but i'm just hoping it will. Took me awhile to decide if I wanted one or not but this forum helped me decide that its a good option to add to my vehicle
Hello
Here is the best option I have found for the backup camera/external video input to a Nav System.  They even have a video showing how to install their adapter.  looks very easy.
http://www.audioandvideointerfaces.com/home.htm
Thanks
MrBossman
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
If it is possible to copy the disc, I would assume you must use a dual layer dvd, since the disc is over 7GB? Has anyone personally done this? Also, would anyone happen to know where one might be able to find an .iso of the disc? This is, of course, for backup purposes only, as some of us may have scratched the original DVD, yet we still own the copyright, and just need to replace the data.
Apparently the Envoy Denali has a Lux amp. I just checked my glove box and it did infact say Y91. So now I guess I need the part numbers for a lux Touch Screen unit. Thanks everyone for all of your help
<{POST_SNAPBACK}>
TNR lux touchscreen is no. 10377531
<{POST_SNAPBACK}>
15204335 will work as well for a Y91 setup--I replaced the factory-installed INR in my '04 DXL w/ it.
    • Howdy! New to the forum of course! My name is Casey, just picked up a 2024 high country midnight edition. First “new” truck in 24 years for me. Driving a 1998 Z71 since 2002. Have been on the GMT400 forum with lots of good info and help there. Nervous about driving these newer trucks and all their electronics…. Did a lot of work on the Z71 myself over the years. New truck is definitely a nice upgrade after 24 years. Photo of the old and new, still keeping the Z71 - has 320,000 miles on her and still running well!
    • We did 250 on our tractors until we switched to Amsoil. We doubled after that.
    • When I was there, most to all did not have an hour meter. They just did 5000 miles on regular vehicles and 3000 on police stuff. The modern oil change monitors should take into account engine hours, weather, etc. I don`t use the monitor on my stuff. I pull the stick, look at it, smell it, rub it between my fingers, etc. That`s my oci.   I have had many engines. Some bracket race. No problems doing things my way. I was in the mechanic business for 30 yrs or so. I still do things the old school way. Don`t care who laughs at me.   Understand, I was in the main shop. We didn`t do oil changes or tires. We had a service station for that. I don`t remember the hours they used for tractors, lawn mowers, etc. Something in my head says 250 hours.
    • I don't know how far back vehicles had hour meters, be it driver accessible or diag accessible but was wondering if there was any rule of thumb your shop came up with in regards to an hour limit on engine oil regardless of the miles on the oil.    I know with construction or farm equipment its almost always based on engine hours for maintenance scheduling as no other metric really applies other than a seasonal time limit that one self imposes on items like engine oil.
    • I'm not sure what to say on that mess but I will say that is an odd thing for that mechanic to speculate on as per assuming its been run out of oil a few times as the odds of that engine having instead piled up with a complete seizure would be very high if such events had actually taken place. However there is nothing saying that the oil has ever been changed although once again, what filter was on that engine as that would tell part of the story if its possible to figure out if its a factory installed filter or not. Too many items unknown and a lot of speculation, but regardless of that its one fubared mess that is mind boggling to see for a vehicle that new and its hard to imagine how it ever made it that far in life looking at the top of the engine.    His scanners, I've watched him before here and there and I'd have to say if I recall correctly that some of his scanning equipment is one or two steps up from a child's Exo Sketch 😋
