Got my wheels on
what kinda rims are they? THey look good. Are you selling your stock rims?
I want to put 285/75/16's on my 2002 Z71 Sportside, but I was told they would rub on the front. Do you have any problem with the tires rubbing?
Thanx,
Nick
I have a 4 1/2" offset Eagle 589.They did rub a little but I just had to trim the front air dam a little and trimmed a little bit of the front wheel liner.You cant even tell that it was trimmed. I raised the torsion bar about a 1/2" not beacuse of rubbing but because of looks.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
