Bose System?
I have an 03 silverado stock stereo setup with 2 speakers in the front door and one in the back door on each side. My stereo is stock with the cd and tape with the theft system. How do you determine if it is a bose system and if it is wheres the bose amp? Anyone switched out the stereo and is it very easy to bypass the security stuff and still have the door chime etc etc? I do not have on star if that matters.. Thanks In Advanced!!!
I believe it's been said before, bose is a stereo place's worst nightmare. Nothing with a factory bose system is easy wired. With four speakers though, it's not a bose system. Usually, it'll say "bose" on the speaker grilles.
I've also heard horror stories about the 03 and later head units. But to keep everything normal and working if you get a head unit, you'll need these:
Receiver Harness
Receiver Mount
Antenna Adapter
"Keep Door Chime" Module
not to mention lots of stress...
Honestly, you should talk to wingnut about how to make a stocker sound like a dream. He'll tell you how.
How would you know? You havn't heard it. :confused:
Chances are, if you don't have OnStar, you don't have Bose. But like he said, it would be on the speaker grills, the head unit, and probably in at least two other places...They are proud (they shouldn't be) of that label.
I'm a strong proponent of keeping the stock head unit and changing out everything else...But I've had more than a few taken out of the truck when I wasn't looking, so maybe I'm just paranoid.
Swapping out a head unit is pretty easy these days, on these trucks. Just add a few bucks to the price of the head unit for wiring harness/adapter and slap it right in there. Shouldn't take more than an afternoon. Several people here have done it, and can help you troubleshoot if you run into problems. :seeya:
I saw it, and if it's put in there right, it has to sound good. Plus you have kickers :seeya:
  • 1 month later...
I replaced my headunit and I have Bose/OnStar...and yes it's true that it's an installers nightmare. Believe me, they will charge extra for that crap too, but I highly recommend that you pay the extra money to get it done right. Only a very few individuals can effectively bypass it.
Oh, it's easy enough...It's just a PITA with all the adapters.
Not to mention, to keep your Onstar capability, most of the time, you have to keep the original head unit hooked up in the truck somewhere.
This is another reason I retained the factory head unit, and just replaced everything else.
So, is it possible to just swap the Bose headunit with an aftermarket?
I have Bose with no On-Star.
I also have an Alpine headunit laying around collecting dust.
Everytime I see post regarding the Bose system, it refers to a 2003 or newer vehicle. I have a 2002 Denali with Bose and OnStar. Will I have the same issues when I get ready to replace? Actually, I would prefer to keep the stock look and just upgrade the speakers. Wingnut, if you would be so kind, explain what you've done to your system. How can I bypass the Bose?
Yeah, I spent a relative fortune getting by the Bose mess. I have an aftermarket Sony HU with XM and just getting that going while retaining the door chime was fairly expensive. Unfortunately, you need to keep the door chime active to pass inpsection in Texas, I was told. After some shopping around, I found a place to install my Sony radio, XM tuner, and all of the other trimmings to keep me legal for $300 and that included a new XM antenna since i was too lazy to pull it out of my previous vehicle before trading it in. Now, on a side note, hooking up this aftermarket radio to the factory Bose speakers made them sound horrible! I knew that this was temporary since I had a couple of amps and some JL Audio product sitting at home. I imagine that if you replace the factory radio AND swap out the Bose, you will have better luck. BTW, I have an LS Tahoe and don't have OnStar...
hope this helps...
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
