New Yukon Question
Our Yukon has the traditional 4 buttons for the transfer case- Auto, 2WH, 4WH, and 4WL. On some of the new ones I see there's three- the top one has something to do with Stabilitrak, the middle is All Wheel Drive (I assume) and the bottom one's 4WL. Can someone expound on this system? What mode should be used when?
:banghead:
I think that is the Stabilitrak, which automatically uses the ABS and AWD systems to help stabilize the vehicle in extreme circumstances.
For example, if you are going down the highway, and need to swerve hard in an emergency, it will apply the brakes, or even power, to one or more wheels to help counteract the forces that would cause the vehicle to roll over.
Steve
Bottom button is 4-wheel Low
Middle button should be on all the time, Stabilitrak is engaged.
Top button is for when you want to disable traction control. ie, if you have to rock the truck to get out of the snow.
Stabilitrak sends power to all four wheels, all the time..... aka AWD.
caden442 is right, Stabilitrak is automatically engaged at each ignition start.
Use the top button to override the traction control. This make the driveline behave more like a RWD - can leave a tire scratch if you get on it :banghead: . You'll find that trying to pull this manuever with Stabilitrak on is much more difficult - as it should be. You'd want to leave it on during regular driving. :)
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
