Electrical Gremlins killin me
Just wondering if anybody has had this problem before. I'm taking my truck in wednesday while its under warranty to see if they can fix the problem. All of a sudden, my cruise control, brake lights, and left turn signal do not work. However, my right turn signal and third brake light works perfect. I'm also having trouble with my key flobs only working every now and then as well. Anybody else have this problem or had this problem.
Did you check the fuse? VEH STOP in the Instrument Panel Fuse Block controls the stop lights,brake module and electronic throttle control module. LT TRN controls the Left turn signals and sidemarkers. CRUISE controls the Cruise control. There are also fuses in the Underhood Fuse Block that are related to the items that you are having problems with.
Try new batteries in the key fobs. They are only supposed to last 2 years. You will need to resynchronize after replacing the battery. Hold the LOCK and UNLOCK buttons on the transmitter at the same time for 15 seconds. The door locks should cycle to confirm synchronization. If the locks do not cycle, see your dealer for service.
:banghead:
  • 4 months later...
:thumbs: I'm having a similar problem with my one week old '04 GMC. Left turn signal stopped working. Had dealer replace turn signal switch yesterday. This seemed to fix the trouble until the next day when they quit again. I've scheduled another appointment with the dealer Monday and am hopeful that it will be corrected permanently. How about some feed back on the remedy?
The cruise probably isn't working due to the issue in the stop lt circuit...kinda like when you tap the brake pedal and the cruise shuts off. Could be wiring problem, or something as simple as a shorted bulb.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
