MLB - NL Wildcard
RyanbabZ71
As of today
Team W L PCT. GB
Cubs 85 66 .563 -
Giants 85 66 .563 -
Astros 83 68 .550 2.0
Padres 81 70 .536 4.0
Marlins 79 72 .523 6.0
Phillies 78 73 .517 7.0
GO CUBBIES!!!!!!! :crackup:
They went alright,they went south and right down the toilet.
Now I am admittedly an Astro's fan but I have to say that this collapse by the Cubs has to be one of the worst ever.I mean,they had a 7 game lead 5 or 6 weeks ago over the Astros and now they are 2 out;that's a 9 game swing or roughly 1.3 games/week.
That Chicago bullpen absolutely killed them and the offense disappearing over the past few weeks didn't help much either.From a true baseball fan perspective,it was just unbelieveable to watch it unfold before my eyes.
d**n cubs :crazy: Ill tell ya what it was a horrible collapse. It all started last weekend. Went downhill fast. My whole family as been in a bad mood since than. I guess the curse lives :D
Heres the cubs new sign :D
I seriously can't believe the charge that the Astros made. No way did they have any business being in contention, much less actually winning the wild card.
I had figured the Cubs had it locked but they ran into about the smae luck the 'Stors had around the 2-3 months of the season with hitting a lot of hard shots right at people and trouble with the bullpen.
2 months ago I didn't think the Astros had any chance of making the playoffs. They made an incredible run. It will be a good series. The Braves have cooled off and the Astros have gotten hot.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
