Steering wheel POP!?!
Hi
I have a 2003 Tahoe 5.3L 4x4, when you are driving down the road you can feel and hear a pop in the steering wheel. The last few days it is getting more noticeable. It almost sounds like a broken shock mount, you can even make the pop noise when you are sitting still and turn the steering wheel. Any ideas?!?!
Thanks
:P
Hi
Thanks
:P
You probably still have your warranty, right? Go to the dealer and more than likely they will order you a new intermediate steering shaft. There is a back-order on these. The dealer will also probably check components under the hood associated with your steering. All under warranty.
I have the same truck with the same problem. It is the intermediate steering shaft. Apparently it doesn't hold lube very well and the splines can break. I am waiting for the part to come in to have mine fixed.
