amp install
waxman
I have a 2003 silverado reg cab. I want to install an amp. What or where is the best route for the power wire to go through the firewall. Should i connect the power wire to the fuse box on the fender or directly to the terminal were you are supposed to jump another vehicle. Iam also using a loc does anyone know if both rear speker wires are routed together to the back or do i have to splice in near the deck? Just too lazy to look right now!
From what I've read, it's better to place an LOC right after the wires come out of the head unit. I'd assume that it's because the farther you run the wires, the less power or clarity you'll ahcieve. There's a couple different ones, a quick look through this page and maybe 2 others in the forum will show some results.
As far as running the wire, pull the carpet back from the firewall and see if there's a decent place to run it, i.e a grommet or a hole that's just plugged. You don't want to drill if you don't have to.
I would think it's mandatory (power wise) to hook it up at the battery terminals, since I don't know how'd you hook it up near the fuse box. I got tired of the d**n GM side connectors, so I cut mine and re-spliced them, and just hooked mine right at the connector.
That's basically the same thing I did for my system. I cut a hole in the antenna grommet and ran it through the firewall and under the carpet, hidden the whole way to the amp :mad:
I drilled a new hole up by the master cylinder for my power lead. There wasn't an existing hole big enough for a 4 awg power wire.
And yes, and amplifier needs to be run directly to the battery, or like you said...At least the "jumper" box.
You will get differing opinions on the best place to install LOCs (closer to the speaker, or closer to the head unit). I put both of mine in the dash, right behind the head unit just because it was easier to do that way. It sounds great.
Just make sure that you route the speaker wires, and the amplifier wire down opposite sides of the truck, or you WILL get interference in your speaker signal.
  • 2 years later...
There is actually a big rubber grommet to the right of the brake booster with a big wire loom going into it. If you take a knife and cut a slit in the outer part of the wire you can easily fit a 4 gauge wire through it. I taped my 4 gauge to a straightened coat hanger and put a lil soap on the grommet. Goes in very easily. It will come out right next to the parking brake cable in the cab. from there its easy to tuck the cable under all that plastic trim. I took the power off the little red junction box that the alternator is connected to.
That's what I did on my current truck...But on my '02, it was just easier to drill a hole.
    • Hmm. A real reason to not just use the odometer to determine OCI?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
