100 th post
04-silver
I joined back on Jan. 27/04 and this will be my 100th post. 10 per month I guess.
I move up from a GM-TC Enthusiast to a Senior Enthusiast..............lol.
Anyway its been fun and informative.
:cool:
John
1000th or so here.  :thumbs:
LOL Irymal (actually a thousand and thirteen but whose counting)
Well for me 100 is pretty good, usually with most forums, after about 3 months I leave and move on, anyway a couple more months and it will be a year at this site for me. :seeya:
:thumbs:
John
