Need some lift blocks
Did your truck come factory with blocks installed? If not, you need a 2", if so, I'd go with a 4 ". I will have an extra 2" block with U bolts after I install my 4" block.
Yes it has the factory 2" blocks in it already.  Is it safe to stack blocks?  I have always thought it wasnt?
Thanks,
Andy
Don't stack blocks. You are right, it is not safe.
Agreed, that's not a good idea at all.
If you want to do it right, get a set of lift springs. The truck will be better off than if it had this huge metal spacer below the spring pack.
I wouldn't, just replace your block with a 3 or 4 inch block. I just replaced my 2 inch with a 4 inch and the truck looks awesome. National Tire and Wheel can order you blocks and u bolts from Superlift. Quality stuff.
