First post!
J's 92
hey all! this is my first thread here at GM-trucks.com.. im Joe out of Maplewood MN, i currently own a 1992 chev silverado, 4x2, grey, completly stock for right now... im 17 years old, i have big big dreams with this truck! just thought i'd say hi!
J's 92. :ughdance:
How do i post up some pictures? and umm, for z71tahoe, what do you mean? i dont even know you... there not my car's there my bro inlaws... but i help the work on em..
-J's 92.
ok nvm, i no who you are... just because i dont tell everyone over at ctw that i work on 2 camaros and an impala DOES NOT mean i dont work on them.. now, if you want some sort of proof i can do that.. just godda go up and get pics.
J's 92..
Everyone starts with a clean slate here.
Not one more post about what he does/has done at another site.
Not one, or the poster is gone.
So be it if it gets dirty fast than that is something for us to handle not for you to be dogging on him. That is what is so great about this site everyone gets along with everyone whether they are new or verteran members. And if someone steps out of line than that is our job as moderators to take care of. Thank you.
It can't be put any better than what Wingnut and Silverado Man said.
Z71tahoe96 and DelightfulyStrange,
Either start posting about trucks or cease posting completely. Are we clear on that?
