rust on bottom of door
Got an 02 that has started to rust on the lower doors along the bottom edge. I'm wondering if anyone else has had this problem. I'm thinking it might be the rubber strip that runs along the bottom is holding water somehow. I'm thinking of removing that strip. This is just the passenger door, the driver door is fine. Any thoughts?
Yeah, those lower weather strips trap the moisture between them and the upper door seal, where it eats at the pinch welds for the door skin. The lower ones are just for noise suppression, and to keep mud, etc. from getting up on your step-in rockers. I noticed I had very tiny bubbles starting above the ones on one of my rear doors ( '01 ext cab), so I had my body guy remove them, sandblast, and re-paint the bottom of the door. He said he's removed them on all of his GM trucks as soon as he gets them. I've noticed no more road noise than before and a little more dirt on the step in part, but it's worth it to keep the rust away. Just be aware that they are held on with 2 sided tape, so some paint might come off if you remove them yourself. Just get them fixed ASAP, 'cause rust never sleeps.
I posted on this a while back somewhere. I don't have the rubber strips, but had bubbling along the sheetmetal folds at the bottom of the doors. The dealer took care of it via the bodyshop they use a few years back. As the guy who looked the truck over said back then, it'll come back...and it has. I'll have to take some measures if we get a few nice days.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
