temp-oil gauges
a couple of months ago i installed a remote starter on my 88 sierra,305 250000 mileage.it worked fine everything was good then after awhile the temp gauge stopped working.then a little while after that if you let the truck idle for awhile the oil press drops right off also.this truck is in really good shape and starts and runs great other then that.ive changed the temp sensor and switch checked all the grounds and nothing i still cant get the gauges working properly.the timing is right on also.somebody must know what is going on with it to help me out. do i have to remove the starter because i dont think it has anything to do with my problem
