Ballpoint pen ink on leather
Shaners
Six days ago I had a full livingroom suite delivered. It is all very soft Italian Leather. Tonight I noticed 2 ballpoint pen marks on it. Does anyone know how to get them out? The hairspray and rubbing alcohol ideas scare me a little.
The moral of the story is that you can never own anything nice if you have kids in the house!!!
Oxyclean?
Simple Green maybe?
I'm out of idears...Sorry to hear it though. :crackup:
**Edit**
I asked around, and I'm also getting WD-40 or baby wipes as answers quite a bit.
Baby wipes :crackup:
OK, a girl that restores books told me that they use "Goof-Off" with great success on leather-bound books.
Of course, any of the above should be tested in an inconspicuous location before using it directly on the stain.
Another option would be the leather cleaner that you can buy where you bought the furniture.
I have a whole kit that came with my leather love seat. Havn't had a need for it up to this point, so I couldn't tell you how good it is.
Shane, i've used non-scented hair spray on leather car seats quite a bit. Works like a charm. Just use sparingly, then wipe with warm water/soap to clean the spray off.
Remember, NON SCENTED. :crackup:
I got it out!!!
I used a diluted rubbing alcohol. Followed with alot of dabbing with the solution and then blotting with a clean towel. Finally I put some leather conditioner on it when I was done.
This method works very well, just DO NOT RUB. Just dab and blot...
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
