Hummer H2 SUT Review Request Thread
Zane
Hummer is providing GM-Trucks.com with H2 SUT for one week in order for us to review and drive
2005 HUMMER H2 SUT Review Request Thread
Place all requests for video, pictures, etc.. in this thread.
:cool::):cool::D:cool:
EDIT: Added real picture of H2!
Take the H2 SUT and compare and contrast it with the Silverado with Quadrasteer that you tested several months (or years) back. List any similarites (other than the parent corp. and drivetrain) or differences that you note from the vehicles. Put your answers in essay format and cite specific details where applicable. You must put your name and your student ID on the paper to recieve credit. The essay will begin now.
:cool: Thanks, Mervz!
Can someone clear something up for me....is the H2 SUT, the H3?  I thought this was being called the H3?  Or am I crazy?
I think the H3 is a new smaller looking Hummer that hasnt come out yet. I think. Not really sure at all. im drunk
The H3 is a "baby H2" (if you will), more fuel economic, and well.. smaller. :D
Sound's like bob1527's having an awesome night. :cool:
I want to see it.......no wait. I don't want to SEE it, I want to see a blob of mud resembling an H2 SUT. yeah, that's what I want.
now get to work :cool:
Gas Mileage as you bring it to OH for an additional reviewer's comments.  Ha, I wish.  Photos of the bed size would be good for starters.
I'd like to see how much actual payload you can fit in that bed, and as said before, I'd like to see it in Real-world off-road conditions.
Guys, I've driven one, and that bed is....Umm....Good for groceries.
Seriously, there really isn't even enough room for all that many groceries.
Not to say that I wouldn't own one...I would, just not for it's cargo capacity, that's for sure.
    Policeoff01
    Policeoff01
  • Who's Online   4 Members, 1 Anonymous, 745 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
