01 denali problem
My 2001 yukon denali has two problems. The first is that the interior lights at night dim when you step on the brake, and you can see the volts go down on the dash meter, then when you accelerate they go to normal?
My 2001 yukon denali has two problems. The first is that the interior lights at night dim when you step on the brake, and you can see the volts go down on the dash meter, then when you accelerate they go to normal? The other problem is maybe from the transmission? or transer case? im not sure, but when you go from drive to reverse theres a delay then a bump into reverse. Then when you driving normal (30mph) and say your coming to a red light then it turns green and go to continue theres another bump, almost like its stuck in second? please help?
I am not sure about the trans/bumping problem, but I will tell you there is a lot of noises these things make that is considered normal. As to the lights dimming, I would be willing to bet you have a weak battery. Is it the original? I had to replace the battery in my 02 in the fall and it was doing some weird stuff up until the time I replaced it that I really did not relate to the battery, just figured something was screwed up. Well, when I replaced the battery things went back to normal. Just my $.02. I would not think your alternator would be bad already. Take her to an autozone and have them do a free battery/alternator check. I am figuring the reason the lights are dimming is due to the electrical load of having the brake lights come on.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
