1995 Suburban Actuator
:banghead:
Ok, now the actuator will not retract when I go back into 2wd. I can bench the actuator and applying power to one pin and it retracts fine. In 2wd the female connection associated with the retact pin on the actuator has NO power, in 4wd I get power to that pin and one other.
What a pain....I think the reason the front diff went out is because the previous owner didn't realize it wasn't retracting resulting in the front always in 4WD though not through the transfer case....I don't know.
To refresh; I have the motor driven actuator (the retro fix to the two wire original version) on a 95 Sub.
Must be the transfer case sensor???? The same wire they tap off of for the retro fix has power in 4WD but not in 2WD....
Thoughts???
Wendell
VERY frustrated Suburban owner.....
:ughdance:
This is for all 48 of you who read this post but didn't have any suggestions. Check the darn wiring! Who ever did the upgrade didn't splice the correct wire coming out of the transfer case switch ( three wire sensor ). Seems they thought they were supposed to tap into the blue wire, the instructions clearly state to tap the brown! I did lot's a head scratching becuase I assumed whoever did the upgrade did it right! Once again the addage goes; when you assume you make a .....big ...um, mistake. NOW it freewheels like it's supposed to. I think the original owner, whom I bought the Sub from either bought it this way or paid someone to do the upgrade and have likely been driving it around FOR YEARS with the front locked in 4WD!
Hope this helps SOMEONE........
Wendell :ughdance:
Final update with this issue:
The original owner took the vehicle to a dealer/GM Good Wrench mechanic 4 years ago in Colorado Springs because, as the TSB points out, it wasn't going into 4WD. The DEALER miss-wired the new harness not once but twice and still got it wrong. They had a 33% chance of picking the correct wire followed by a 50% chance if they were picking randomly.
Thanks to all who have helped me so far, I appreciate your feedback and input.
I see you already got it fixed, but I was about to offer up the fix.
I went through this on a 91 a few months back. The new actuator needs power to move either direction and the old one only has power applied to move into 4x4.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
