need some help here...
i have been around enigine for a while and know the three main thing in geting more power and mpg out of vehicles. i have found a good deal of info on the induction and exhaust side of the house. does any one know if anyone makes better coil packs, piggy back system for a better spark/burn.
cant burn the fuel no point in putting it in there right???
thanks
wildman
they look like ls1/2 coil packs??. if they are i get the msd replacement for the better burn. if they are like 50,000 volt i wont mess with them. but usually stock is round 30k
talked to raylar
this is whant ray said.
The coil near plug ignitions and the platnum plugs the 8.1 engine comes
with
are as good as it can get. Don't waste any money or time on some of
these
upgrades touted in some of the magazines, also like hand held
programmers,
power towers, air intakes, they just don't do anything measurable thats
worth the cost. We have engine tested so many items for the 8.1 we have
over
356 dyno pulls on two motors testing every type of performance
enhancing
part made to date. The only things that really work are good cams, good
heads such as ours,roller rockers, our intake manifold and bigger
injectors,
good headers and neccessary reprogramming of the ECM by a Pro. The
other
kinds of so called improvers put a lot of money in some peoples pockets
and
sometimes three horsepower or so on an uncalibrated dyno and allow
them to
take out big glossy ads and articles in magazines that want you to
become a
reader and by everything advertised in there
thankx for they in put
wildman
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 669 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
