Cubby Filler?
Does anyone know of a place that makes something to replace the little cubbies in the dash of a Burb with just a flat plate. I don't have Onstar, and I want to mount my SkyFi2 where that cubby is.
I have one that has a blank filler over the top half and you can snap in two blanks in the lower areas.
The part number for the insert is 15040483 and the two blank covers for the bottom are 15734687 (you'll need two, they fit either side)
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
