Help me find an email program...
MrQuadrasteer
I need a type of outlook, I guess, where I can go to a site, enter my pop and smtp addresses and check that email account from any computer. Right now, I can only check it from home on my outlook.
EB
My suggestion would be to use a email site that supports both pop 3 (use outlook at home) and a web client (in a browser anywhere) front end for email. There are several out there.
There are many. Yahoo. MSN everybody will give you a free email address. Your internet provider provides you one also(or several). Who ya signed up with? Heck where do ya work they may offer one also. You can have as many email addresses as you want. They all have address books and calenders and the like. i personally use yahoo just because it's there and no other real reason. I have never had a problem.
Here's the deal. Outlook just interfaces with your e-mail server. Right now, you may be able to do just what you want. Put in your mail server name and account info on my computer, for instance, and you theoretically can read your mail. Here's the problem, some providers will only allow you to use that method from within their network. So, if you were to do this procedure on your work computer, to use Outlook to check your RR mail, it may not work because your work computer does not connect to RR's network directly (I'm assuming this is the case).
I use Mozilla Thunderbird, I download all my mail to my HD when I'm home. When I'm not, I can use a web page interface to read the mail I have on the server. My family has bought rights to a domain name, for e-mail purposes for now, our mail is hosted through www.twistedbits.net We have POP access and webmail access, but I could also use an e-mail program on any computer to allow POP access to it from anyplace, to make it act just like at home. I don't have the network restrictions like ISP-based mail accounts have.
I hope that wasn't too confusing. I work in IT, stupid questions don't bug me, so if you have any about this post, feel free to post them.
Since you are using a pop email account the only way to do it with out losing it would be if your email host has a webmail service. The way pop accounts work is that it takes your email (it "pops" it) off of the email server. It is then on that local machine. So if you use outlook at home using a pop server you can not go to another computer and search through your old emails. You will however be able to pop off your new emails but then they would not be availible for any other computers.
It would be a completely different story if you were using something like a Microsoft exchange server.
Same goes for me. :(
I haven't used mail2web in over 2 years only because I no longer travel for work. I used it to access my ISP email account with no problems. Their website states the service does not download or delete your messages. You can read, reply, or forward new messages. Hope this helps.
http://www.mail2web.com/
I use either of the following:
www.mail2web.com
www.myemail.com
There are several others out there as well but those are just two. I like myemail.com better than mail2web.com but it is all a personal preference thing.
B.J.
Thanks for all the help, gang.
The two links above work for my @ev1.net addies, but not this one. Since it's an Infopop addy, think they restrict that sort of thing ?? It always gives m an error when trying.
To be clear, this is my mrquadrasteer email in my sig. I'm not needing a new addy, I already have unlimited ones thru ev1.net. I just can't check mrquad's email until I get home and it bugs me !!!
I'm gonna contact the infopop support folks.
Thanks again.
Outlook can check mail on any server that has a POP3 mail server. All you need to do is supply the server names and account info. Sending mail is another story and most mail servers (SMTP) restrict it to what is actually "connected" to it (dialed in or through a LAN) to prevent spammers and other abusers.
Quite a few also have WWW based access to your mail as well in case you don't have access to a real mail program.
Yes Outlook can, but unless you archive the mail into an Outlook .pst file that mail will not be on the mail server anymore and not be availible to other computer. It is best to not pop mail off the server unless you are on your main computer.
You can tell Outlook to leave a copy of the message on the server instead of deleting it after downloading it.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
    • Same here, first I bought a few filters to get me going right after I bought my truck to do some short distance initial oil changes, then realized I could buy a case lot for less as they drop the price if filters or trans oil etc is bought by the un opened case lot as well as the discount for buying the vehicle there. So I have filters for a while but its good to know going forward, knowing to expect it to be a different part number and looking filter at the dealer and not be confused over it and think they are handing me the wrong part.
    • Saw Inglewood was in the National New last night for hail. Allot of hail. front end loader level hail. 😱
