Bought another chevy!
1 Bad Burb
hey guys,
i haven't been active here lately, been busy with work and school..but i had an opportunity to pick this bad boy up... so did...
enjoy..
also, the stickers will be taken off, i don't like to advertise what i have...
Aj
Link to Vette
