Auto Show in Motion
Got an invite to this in the mail. Thought that some of you might be interested. There are several locations around the country still on the schedule...
You can register at this site if your interested. It's free! I'll be attending the event at Lone Star Park in Grand Prarie, Tx this Sunday!
Auto Show in Motion
James.
Going to my first in two weeks :thumbs: !!
Got an invite last year, blew it off cuz I figured it'd be lame. A friend at work went and said it was awesome !!
PS- Save the Vette for last, that way when they ask you to leave cuz you drive like a maniac.... :thumbs::eek::flag: !!!!!!!
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
