2003 roof running lights
I bought a set of running lights from Cabelas. $77 with shipping. I went to my local GMC dealer to measure exact light positions on a truck in their lot. I heard the lights from Cabelas looked a lot like the GM factory installed. To my suprise they are the exact same light. I know you can get them for $55 as an option if you order your truck but I bought mine new off the lot. They were not on the truck and the dealer wanted about $350 for the lights and installation, no charge. This was to be a favor type job since I bought the truck from them. I was told that through the parts department that the three lights and harness alone were about $350. How (or why)do they charge so much when it is only a $55 option to start with??????
Anyway... My question.
Has anyone installed their own lights and what wire in the headlight switch will I splice into to get the lights to come on? The instructions only tell you to splice into to headlight switch but do not give a wire color. Is there a place in the fuse panel to connect the wire. By the way the supplied wire has an inline fuse. Or is there a place to connect the wire into the switch were the factory running light harness would go? I have not yet tried to install the lights. That is a Saturday job. So I have not yet seen the switch to know.
Any help will be greatly appreciated. If I can figure out how to post pics I will take one of the final installation.
Thanks
Tim
Go here for some messages on this back in 2003:
http://www.gm-trucks.com/forums/index.php?...&hl=roof+lights
Thanks for the info. I know this will make the job go smoothly. I can see from the posts in the past that the GMC dealership was giving me a screwing along with the "favor" installation. Looks like the parts are only about $135. They quoted me $55 each for side lights $155 for center light and $85 for harness. I thought the prices sounded a little high. They were wanting to regain a little $$$ back from me. I bought GMS and probably paid less for the truck than the dealer. I know GM gives them money for making the deal. OH well...
Lights go on in two days. I'll take pics.
Thanks again. :cheers:
Tim
I have installed 5 sets of them on my two differant trucks and friends of mine, I ran the hot wire through the fire wall and spliced into the drivers side parking lamp wire (used a volt meter to find the right one) but do yourself a favor and run a bead of sylicone around each light gasket that sets on the roof to prevent leaks and after you finsh the install get some black touch-up paint and dab it on the screw heads to stop them from rusting, but I think when I get some time and when I think about it iam going to take the original screws out and replace them with stainless screws. And another thing, I pulled the light bulbs out and put some bulb grease inside each light socket to prevent corrosion (just to be on the safe side).
timowen1,
I would advise you to get the harness, it makes the job much easier. As, it plugs right into the access panel on the passenger side.
Here is a picture of where I put mine. Be careful when drilling the holes, the roof is as thin as a soda can ..very easy to dent in.
Measure, Measure and remeasure before drilling the first hole, as you cannot redo it again.
timowen1,
Kenworth-1
In the picture I see about 5 harnesses pluged in, all different colors. Which on is for the lights. I only have room in my connection block on passenger side for 1 plug-in and it seems to be blank(no electrical connection) I seen on a past post that someone calls out a harness part number with about a $20 cost. My local dealer is still quoting me about $85. What did you pay for yours and do you still have the harness part number?
Thanks
Tim
The Harness # is 15366160, this was for an 02 HD..so, I dont know if, this is the same number you would need for the 03...I dont remember the price, however, you can look it up at one of the Vendors who sponsor this site...If, I recall, it was not that high, but, I would have paid anything not to splice or cut wires. The plug with the two wires coming out is the one for the harness. The Lights look great at night!
Definitely, get the harness. Just plugs in to the socket on the passenger side. Don't worry which socket, only one will fit. The part number is the same as above and can be had at http://www.partszoneonline.com/ for $27.67 with $18.54 shipping. Now look........ You don't HAVE to buy the harness but snip and hack into your $35,000 truck's wiring and build your own. But this harness not only plugs in but, also has push-ins to anchor it to the A-frame and roof. Prevents that on-again, off-again rattle that you can't figure out.
The lights can be found at several vendors, but I have used:
http://www.autobarn.net/rodi/higfivligkit.html
You know that any project requires some thinking, some commonsense, some trimming. Re-read the messages that we all hashed out a couple of years back. I have installed a few of these and the little boy in me still smiles when seeing those lights on the roof.
If, I'm not mistaken...Clear or Smoke Cab Lights are illegal on the road, if, lite up at night. Correct me if, I'm wrong, but, I'm pretty sure they are not allowed.
Certainly would be wrong if blue or red bulbs are installed in the clear. I'm not sure if only amber are allowed on the roof. That's a good point. I'd ask the DMV.
Good, point... Thanks for bringing it to our attention, but they way i look at it, tinted windows are illegal and loud exhaust as well. If your willing to deal with the consequences just to have a nice look then thats up to you. Myself, i dont know, i'll have to think about it harder now that you brought that up.
I had cab lights put on at a local accessory shop and it appears they did a great job. I made sure they used a lot of silicone. The total bill was $145 it took them 2hours to do. they look assume and really set the truck off.
2001 2500hd 8.1
timowen1,
Kenworth-1
Thanks
Tim
Kenworth1,
The picture of the junction block there - what all is that used for - besides the roof lights?
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 511 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
