How do you talk?
Bgdsub72
Interesting, the first time, I was at something like 30%...But if you change an answer it goes to 100% Dixie, and won't come off of it.
55% (Dixie) Barely in the Dixie category.How I have no idea!! Oh Well,you learn something new everyday!!
This is an repeat thread of the same thing that someone else posted here a long time ago, but I still played it anyway.
32% --> A definitive Yankee :cheers:
83% Dixie
wow
I know once you get up in Northern parts of OK it gets a lot different. But most people say I have a rather tame accent for this area. Can't imagine what some people around here would score.
48% (Yankee). Barely into the Yankee category.
My friends say I get a Southern accent around my Mom's family though. My Mom's parents are from Texas and Arkansas and have accents.
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
