12V + on trailer harness not working
ga1990
I have a 2003 silverado with the tow package. I just put electric brakes on my trailer, everything works fine except for the trailer disconnect wasn't charging...i tested everything and it turns out that the pin that is suppose to be 12V + on my truck is dead. I assume it is suppose to be hot as long as the truck is turned on? The battery from my trailer disconnect relies on this 12volts to charge...I've tried everything I could think of to make it to work(truck on, brake controller on, towing mode on) but still nothing. Is there a fuse somewhere for this or something else I'm missing? As you looking at the 7 pin plug, this would be the first pin to the right of notch at the top.
Check your owners manual for the fuse placment.
The fuse for that is in the fuse box under the hood. It's one of the big ones. They come from the factory without the fuse installed so I'd say it was either never put in or it blew. The positive pin at the back of the truck should have power all the time no matter what.
On my friends '03 1500 we had to connect the 12 volt power / trailer positive wire in the fuse terminal under the hood.
You have to remove the plastic surround (shroud) in addition to the plastic lid on the fuse panel. then there is a wire that needs to be put on a post and bolted.
check your fuse cavity with a test lite, pull the fuse and check to see if you have power to the terminal before you remove the plastic shroud. if you do have power then you already have the wire connected. no power, then you need to connect the wire.
Check the fuse panel under the hood and find Stud #1 and check to see if has the red dummy fuse in it. If is does replace is with a 40amp (i think that is the size) fuse and it should work.
Thanks badgerman, that's what I did and now everything works....I don't know why they don't atleast tell you that in the manual...all my owner's manual basically said was "Stud #1: do not install fuse"
No Problem :P
There is also a topic going on about this, it should be close to the top of the new topic list and it kinds of explains it.
I just found this info out today on this forum.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
