Sirius and XM
Can you get a box like we have for XM in an 03 Silverado LT Z-71 that is a box for Sirius and run the the HU like XM or would you have to get one of the adapters ive seen and run it thru and aux input?
Thanks,
Amos
Thanks,
Amos
Yes you can, and I have one, and it is awesome. Sirius beats XM hands down. It is made by soundgate. You can pick one up for about 99.00 from various soundgate vendors. I got mine from logjam electronics on the web. Plugs right into the back of the HU, you use the band button to go from fm1 fm2 am sir1 sir2. You get 12 sirius presets. It uses the kenwood receiver, got mine for 40 on ebay. Mounted the sirius receiver with double sided HD mounting tape (the foam kind) to the underside of my cup holder tray thing (center console). Ran Sat antenna out of 3rd brake light / sealed with black silicone. I can get you pics if you want.
I also prefer Sirius to XM and use a soundgate adapter purchased from logjam. From what I've read you have to disconnect your XM and cannot have both at the same time running through the HU as you described.
Here's a good write-up that I was directed to when I installed my Soundgate. Make sure to read the part about pulling out the blue tab to disconnect the xm receiver (i spent way to much time trying to figure that out).
Will this work if you don't have XM from the factory. Looking to buy a new truck soon and I can't see paying for the XM and then switching to the Sirius but I would like to be able to control it through the head unit.
Yes! I can't wait until someone comes up with an adapter to have XM and Sirius at the same time thru the factory HU. LSU Fan, where are you?? I'm in BR.
I'm in the big BR. :P  Went to Duplesses today and test drove an extra cab Z71 and was pretty impressed.
Got mine from Gerry Lane. I love mine, even though it has its quirks! You should be able to get a great deal right now, with gas as high as it has been. I did see that Brian Harris was running some good sales in the paper last week, but they were the deceptive ones with the stock number by the truck in the ad. I hate that look at a truck for 24 thou, get there and they say, oh we sold that one but we do have these for 35!!!!
Great thread folks. My truck came with factory XM and despite the fact that they have the NASCAR channels I really would prefer Sirius because I'm a rocker. XM rock channels stink. They don't know what rock is.
One question, since I already have XM can I simply use the same antenna? I don't really care if I lose XM but it would save me some pain by just being able to use the same antenna. Can this be done?
From what I've read... you cannot use the same antenna. I'd love for someone to prove me wrong though!!
Guest 007FL
I can't swear to it but I'm guessing you can use the same antenna. I say this only becasue I added an Alpine XM to my HU and it came (used) with a Sirius antenna. It works fine.
  • 6 months later...
Just a note about the antenna. I installed the Audiovox Sirius radio kit this weekend in my truck. It has the Bose 6 cd system w/rear DVD and XM. I like rock so XM was not adequate at all. I was able to use the factory antenna for the install. In my truck, the antenna cable is different than the pictures above. It's a single tan wire coming into the XM box. The connector on the end plugged right into my Sirius radio. I was very surprised by that. I had to extend the cable for my mount anyway but it's working great.
Now, a question. I was not able to find a 12V source that would stay on like the radio does after I shut the truck off (until a door is open or 15 minutes passes). I was also unable to find one that stays on in the ACC key position. So the truck has to be running or the key in the run position to have the Sirius on. Can anyone tell me where to pick up either of the above 12V inputs?
Thanks
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
