ECC With a mind of it's own
aviator
I've recently traded in a much-loved '02 Avalanche for a used '04 2500 4X4 Crew Cab 6.0 with 27K miles. One of the options it has is the Electronic Climate Control, which is a great idea, but mine seems to have a mind of it's own.
I can start the truck, put the ECC in auto mode, set the temp and drive off. For Example, I can set it to 75 Degrees and the dash vents flow warm air, it's 48 degrees outside. a few minutes later, the ECC changes the vents being used from the dash vents to the the defroster The temp doesn't change.
Once the system has switched to defrost, I can't get it to change to any other vents, even by taking it out of auto mode and manually selecting other vents and changing the temperature (up or down) but the temp will change; it always blows out the defroster vents.
Now, once I turn the truck off, then back on, it will switch the vents to where they are supposed to be according to the read-out. Eventually it will go back to defrost though if I put it back in "auto" mode.
What's going on? Does it sound like I have a defective unit or is it supposed to use the defroster as it's main outlet for conditioned air? Sorry for the long post, but I tried to be as detailed as I could.
Any help would be appreciated.
Mine never goes to the defrost vents on Auto. There is a defrost pushbutton on the control module I have to press to get it to go to defrost. Also, when it's in defrost mode, there is a defrost indicator on the screen of the module (looks like a windshield with squiggly lines on it).
Maybe your pushbutton for defrost is sticking on. If you cycle between defrost and auto does the indicator change on/off?
Yes, the indicator changes from on to off and back when I cycle through. I thought the same thing initially, until I saw that the indicator was working properly.
GM HAS A TECH SERVICE BULLETIN ON THIS PROBLEM...
THE HVAC WIRE HARRNESS TO THE MODE DOOR ACTUATOR MAY BE RUBBING
ON THE INSTURMENT SUPPORT BRACKET AND GROUNDING ITS SELF CAUSEING YOUR CONCERN
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
