sub box design
I have a question about a sub box design. I have 2 12" Solo-baric Kickers and I'm trying to build a box for the ext. cab part under the seat. They will be downward firing so the top of the box can be used to put stuff on if I raise the rear seat. In designing this box, should I construct it as two separate boxes that look like one box, or one big box holding the speakers together. Any help will be appreciated. Thanks, Chris
Bad news. You can't use both. You don't have enough volume there. Each needs minimum of 1.2 cf internal volume after subtracting driver and bracing. If you do it, you will have nearly no volume under 60 HZ.
You will have a great sound with just one though, so you should maximize volume across both seats.
FWIW, I always design duals seperately chambered for one reason. If they were uni-chambered, and one of them blew under high power, the other one would interpret then that it has twice the volume, and it would probably blow instantly. In seperate chambers, if one blows, the other doesn't know it, if you are running stereo subs.
Yeah man, I would just use one of those subs in your situation. I really haven't heard any dual 12" down-fire setups that I've liked. If you really want to do a downfire configuration, I'd find a pair of 10" subs that don't require so much airspace, and I would build two separate boxes. Two separate boxes makes it easier if you ever need to take them out of the truck. I'm not sure if you're asking about boxes or chambers. Each subwoofer needs it's own chamber.
According to the specs I got with the Solobaric's, they only require .88 cubic ft. of space in a sealed box, that's why I got them, they don't need as much air space. After doing measurements and putting them in my AutoCad program I should have .94 cubic ft space, which should be enough. I should have plenty of room to build two boxes under the ext. cab seat, I will be removing the jack. The design is for each sub to have it's own chamber, either as 1 solid unit or two separate boxes. A truck like mine had this setup with these exact speakers, the sound was tight. I don't like loud, booming bass, that sounds great when your outside, but like crap when your inside the vehicle. I don't like distortion, I want clean, tight bass with good mids, I've already replaced all of the other speakers in the truck with infinity speakers. I'm going to start on the box tomorrow, I already have all the patterns, just need to do it. I'll post back after I get it done. Thanks for the help! Chris
Awesome. Well in that case go with two separate boxes! I would like that more than one big box. Let us know how it sounds, and make sure that you have enough room between the subs and the floorboard so that they don't hit.
Well I finished the box. I made 2 separate boxes and just screwed them together and covered the whole box with gray speaker carpet. The amp I was going to run them was a Reference 500 by Soundstream. The amp is a couple years old, I've run it in my wife's 4Runner since I bought it. For some reason it keeps blowing fuses, I know it's wired right, as a Sony Xplod amp does not blow fuses, neither does my Crossover. I guess I'm going to take it to Radio Shack to see if they can fix it. I don't want/wife won't let me, buy a new amp capable of running these speakers. Just when I thought I had everything going smooth, something else happens. So until I get it fixed, the speakers are just sitting under the back seat. Would the Xplod amp (222W) 40watts RMS 2 channel amp, be enough? I don't think it would sound as good as possible with that amp. Any ideas? Thanks, Chris
what fuses are you popping? Amp rating? What gauge wire have you run from the battery to the amp? Did you you fuse the battery lead? Is the amp grounded with same gauge wire? Where did you ground it?
40 W rms? No.
I'm blowing the 20 fuse in the amp itself. No other fuses are shooting. It's 8 gauge wire for both the battery 12V and the ground wire. It's grounded to the frame. The remote 12V wire is 12 gauge. It must be something in the amp itself, not the wiring. I've hooked up 2 other amps, no problem blowing fuses, both of them have 20 amp fuses as well. Chris
a 20 Amp supply to feed those 2 drivers is probably low, but as you say, other amps are doing it. Does the amp get real hot? What impedance load are you running in parallel configuration?, mono? stereo?
Normally I look for 50 amps plus for this duty.
If you're blowing the fuse on the amp, it sounds to me like you don't have the subs wired right. Does it play for awhile, or does the fuse blow immediately?
There have been a few of these amps on ebay recently, and some are "as-is" and don't work. So this amp might be approaching the end of its life. One of the completed auctions shows fuses on the back side (carpet-side) of the amp, some of the others have a single fuse on the wiring-side of the amp. Which configuration does this amp have? If it's a single fuse version, 20 amps sounds a little light for 500 watts. My sony xplod has a 60 amp fuse for 400w RMS.
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
