93 Suburban K2500 questions
dogdays
Vehicle: 1993 Sub K2500 5.7 4L80E
1. My transmission sometimes will not shift into 3rd or OD. I am planning to change fluid/filter but have read the screens to the solenoids sometimes get plugged with debris, causing these problems. Before I yank the transmission and get it overhauled I would like to try to clean out these screens which are in the valve body. The FSM describes the operation with transmission upside down. Is there a decent chance of success in taking off the outer part of the valve body and setting the checkballs with Vaseline to keep them where they belong when I reassemble? Any gaskets to buy?
2. As soon as I turn the ignition on or off I get a clapping sound from the HVAC unit. It is the recirculate door which flaps back and forth for more than 15 seconds every time I turn ignition on or off. Where do I start looking for the problem?
3. On startup the injectors go wild and spray tons of fuel for about 20 seconds. I have replaced MAP, TPS, Temp sensor, O2 sensor, knock sensor, checked operation of the IAC, and looked in the FSM. Not all of these replacements were to try to fix this problem. In addition no codes are set during these episodes. I have to hold the throttle open to keep the engine running and the exhaust stinks like gas. After a length of time it will idle and run fine. I have followed the troubleshooting keys in the FSM and have no idea what's the problem. Left to my own devices I would look for a rebuilt ECM next. Do you have any suggestions?
Thanks,
Rich
Lakewood, CO
1. I'll have to talk to our tranny tech tomorrow. I'm not a tranny guy even though I know enough to be dangerous. Still, don't see many 1993's around a dealership anymore, so I don't know what sorts of problems they used to have.
Dropping the valve body is not difficult... The spacer plate gaskets will probably be molecularly bonded to the spacer plate by now. :thumbs: That'll be real fun. If the plate comes down with the valve body, the check balls will be in the right place as long as you bring it straight down and don't jiggle it at all. We hold 'em in with "trans goo" but vaseline will work.
On the other hand, the solenoids can be removed without removing the valve body, so I'm not sure why you want to drop the valve body. I wouldn't unless absolutely necessary. As for crud in the solenoids... I doubt it.
2. I recall something like this problem. I just don't recall what caused it or what fixed it. When I go in tomorrow, I'll ask one of the other guys that's done AC for quite some time if he remembers.
3. Does sound like a possible PCM, but try removing any and all connections from the distributor and see if it still sprays with you turn the key on. Seems like something about the distributor comes to mind, but I could be thinking of something else.
#2 and #3 sound familiar, but jeez, a '93! I have a hard time remember last week these days.
Just putting it near the top again. This weekend I replaced rear brake shoes. After 206,000 miles the original drums were barely worn, the original shoes were more than half-there. I hope the new shoes will aid in stoppiong the Sub.
But my other 3 questions remain.
R.
I am still waiting.
1. Tranny tech says, "never heard of the solenoid getting plugged with debris. Debris hanging up a valve in the valve body, yes."
2. No definite answers. Possible door hanging up.
3. Do the suggested action and we'll go from there.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
