pulling positive cable to reset
I'd be interested in knowing the answer. . . Doesn't make sense to me though - the air mass sensor should pick up a changed reading immediately; hence, why there's a sensor there to begin with.
Heard someone say that if you dont pull batt cable to reset computer your engine wont reset for the more air flow. is that true?
Scott
You only have to do that if you stood on two feet with your toes curled up when you installed the K+N. :chevy::D
Scott
Pulling the battery cable makes the "learning" go back to square 1 and your truck starts to re-learn how to run with the new components. When I put an exhauat and intake on, I did not reset the computer. I drove it for a few days and read a post regarding this re-learn. When I did it, there was a definite SOTP improvement. When you do the reset, your truck will barely idle for the first 10 seconds while it learns the proper air/fuel, timing, etc. As you drive, it also learns your driving habits. For example, when I first got my truck, I would have to really get into the accelerator to get it to downshift. After a while, it figured out that I this is the way I drive and started to downshift much sooner.
Some have even suggested you reset every 6 months or so because their trucks seem to "mellow out" a little after the computer compensates for any new HP adders. Not sure If I'm convinced 100% on this one but in the case of my exhaust/intake, I'm convinced there was a noticeable difference.
Scott
I'd like an experts review on this, I personally don't think GM has built any "artificial intelligence" into the engine modules. They process sensor information, and set engine parameters based on the current observations. Adding logic to set parameters based on 'trending" is pretty complex and would require some significant amount of data storage capabilities like an on board hard drive.
Just my .02 and I certainly could be wrong.
Take a look at THIS piece of GM lit. It says "Adaptive Shift Patterns - Sensors read driving habits and constantly adapt the vehicle's electronic transmission's shift points to individual driving styles. For spirited drivers, the transmission shifts more aggressively, while for economical drivers, there is a different approach...........The control system collects data, "remembers" driving behavior. and allows the vehicle to respond in a more enthusiastic manner."
Not sure what your definition of adaptive learning is but this sure fits it for me :chevy:
I stand somewhat corrected although the only part I saw that was "adaptive" was the transmission shift points. With 512k of memory, 100k lines of code, and 150k bytes of "values" there isn't much room left for much "adaptation". I also have to wonder if this is something that is incorporated into our trucks. We don't have Driver shift control either.
This procedure also is based on the idea that the area of the PCM that has this data is volatile. I don't see why GM would let important info like this collected to improve driver satisfaction go down the tubes when the battery is disconnected. The remainder of the PCM code/values are not volatile and are maintained across a power loss.
I had a Silverado SS prior to this truck, I never noticed a difference in shift points until I had the PCM re-programmed. And trust me, I drove it hard, before, and after the PCM.
Regardless you felt a SOTP change from the procedure, that is significant. I might try it just to see if I can get this new lazy 5.3L to get up and go...
I tried the battery reset after my K and N and Flomaster change. I believe it did work. It was feeling so lazy after the upgrades and MPG dropped. So I reset the Comp.
Worth a try. it worked
SCott
Does disconnecting the battery and doing this reset also get rid of any computer programming the vehicle might have (Hypertech or otherwise)? I bought my truck used so I don't know if it does, but my truck hauls-ass pretty well and can light the tires up without much effort...I don't want to lose any program it might have if I need to change the battery some day.
-Steve
-Steve
The programming should be non-volatile, although the added performance could be some adaptive response to your spirited driving! :cheers:
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
    • The not as clean as one would assume theme with the new engine oil, that reminds me of comments over the years with mechanics not always being so on board with filling an oil filter, not from the center anyway due to that typically being the clean side of the filter, danger of some contaminant falling into the filter if not careful but the realization now that the oil may not be as pure as one had assumed it would surely be. Yes it would be possible to fill from the small holes but that means messing with something to prop open the anti drain back valve if the filter is so equipped and not damage that valve in the process. Me, I have hardly ever prefilled an engine oil filter however I have prefilled diesel fuel filters with a filter on a fuel bulk tank and for anyone that has messed with diesel engines with filters and units that have a limited or no way of priming them, putting on a dry filter is a bad day to say the least with those crappy systems. But anyway back to not so clean engine oil, indeed perhaps its not so bad after all that I have not made a practice of prefilling oil filters.    As Grumpy Bear commented on keeping things clean, that I really have to wonder what the typical practice is at a dealer or any other shop that changes engine oil, do they make sure to wipe or wash off the oil plug and certainly if it fell into some gunk or onto a dirty floor, or that they wiped the filter mounting flange and didn't go and use some dirty rag and end up adding dirt to the inside of the head of the filter mount. Or be careless in how they stored or handled the new filter and if they were bumping into items under the vehicle with the filter opening facing up and having dirt drop right into the filter and if so right into the threaded center that is on the clean side. The top side, did they clean away the built up gunk that may be around the filler before removing the cap or to be really careful at that point that something right close to the filler hole that was hidden under the caps flange won't fall into the engine. Or did they clean the funnel or was that just laying there covered in oil from the oil change before and dust kicked up from sweeping the floor stuck to the oil and now that will go running into the next persons engine due to just not cleaning the funnel as "they won't know anyway" attitude as that young guy is more worried about taking a break so he can go outside and smoke a joint. Just random points that came to mind when I think about what some hired personnel may do that the shop foreman has no idea of or perhaps the whole attitude of some shops may be "eh ... who cares, they will never know the difference anyway".
    • $3.69 for 87 octane.   $4.24 for Diesel in town.
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
