External video input to TNR
I would like to input an external video signal from a back-up camera into my 05 Denali Touch Sreen Navigation System. Does anyone know how to do this and what extra equipment is needed?
Roger
Roger
PAC makes a video input interface for doing just that. The interface adapter is about $350. It is a simple install that requires replacing the factory ribbon cable that goes to the screen in your nav HU and a added switch to select between the input video or the HU's display. From there you can connect your camera to the RCA input cables on the adapter.
Roger
PAC makes a video input interface for doing just that. The interface adapter is about $350. It is a simple install that requires replacing the factory ribbon cable that goes to the screen in your nav HU and added a switch to select between the input video or the HU's display. From there you can connect your camera to the RCA input cables on the adapter.
here is the link to it: http://www.virtualo.net/index.asp?PageActi...PROD&ProdID=111
Roger
Thanks, this is exactly what I need and easy to install.
Roger
  • 3 weeks later...
Would it be possible to connect the rear DVD player to this input through a switch as well?
Roger
I did just that..
Check my photos out: Using Pac module on the TNR, and ran the vdieo from TVIX, and RSE DVD to front screen.
http://www.denalitrucks.com/coppermine/cpg...x.php?cat=10366
Anders
How did you install the switch and external input wiring?
Roger
Roger
I did just that..
Anders
Roger
I left the switch in the ashtray. Also, the PAC module is sitting just below the A/C control, inside the dash. The input wiring is running from the TVIX up the floor boards on the passenger side, behind the glove compartment, and to the screen. The RSE DVD is running from the ceiling alongside the B-pillar, floorboard, glove compartment, to the Screen. Small switch in ashtray too. I use RSE input on the HU, but will get an Aux input soon.
Anders
Roger
I did just that..
Anders
Roger
Anders
Thanks. I am looking at a product from audioandvideointerfaces.com GMTCH 053
This has a built in switch
Roger
