More probs!
I now have some more problems with my truck. Its like one thing after another.  Now the coolant is leaking a little.  From underneath it looks like the coolant is dripping on to the starter and slowly dripping around the starter to the ground.  Some trans fluid is also leaking! It looks like the seal around the trans pan is not good and its leaking from there. Again any suggestions or answers? Thanks
Check the heater hoses and fittings. Try a new pan gasket if that is where the fluid is coming from.
Team Green,
Not sure of the year of your truck, but 10 bucks says you have an intake manifold gasket leak "if" all hose connections are fine and the radiator is not the culprit.  Rule those out first then look for the coolant to leak off the bell housing after shut-off.   Tell-tale sign is a small puddle each evening.   If it is the IM gasket your looking at between ?-? to have someone fix it.
Good Luck,
BIG BLUE
