Happy 4th everybody!!!
Bgdsub72
What are you plans? BBQ, hang with the family, fireworks? Just wondering what all of you are going to be doing. Me, I am going to be at work :seeya: so if you are shooting off fireworks today shoot an extra on off for me!
Happy 4th!!!
Plans hmmm Claybar my front fenders and hood they are pretty rough. Then maybe work in the yard? Wash siding time dependant. Fire up the grill for some burger tonight along with watching fireworks!
Be safe everyone!
Recovering from partying since Thursday. My best friend is on his way to Afghanistan today so the last week has been busy. :seeya:
:chevy:
I bought some fireworks to set off for the kids that live around my apartment complex here. Figure I'll do that later while I'm grilling out my steaks.
Was off thank God, and managed to get together with the folks for an early dinner at the Olive Garden...very 4th of July-ish I know. Well I did take the bike there, so I was able to squeeze in a local lot down the street from them and watch the fireworks from the park that we used to go to a lot when I was younger. :seeya:
