Front Speaker Mounts
i just got some new speakers for my 2003 silverado regualr cab for the front door, the door has the little tweeter plus the 6 1/4 speaker. taking out the stock speaker i realized they use a plastic clip in mounting thingy yea that. anybody know if there is an aftermarket piece that will allow you to put ur new speakers in a similar thing then just clip it in???
thanks
I mounted tweeters on the interior door panel (behind the grill). Then used the plastic, modified to mount the new driver. Dynamat it.
thanks
I think you're referring to the 6 1/2" speaker's mounting, right?
Even though GM uses those plastic snap-in brackets, I think they do that so that the speaker is installable by the guy on the production line in .05 seconds, which equates to .001 cents savings, so everybody wins!
But when you're already spending hours doing your sound system upgrade, a few minutes extra time spent screwing speakers in is nothing. Otherwise if you tried to reuse their snap-in plastic adaptor, you could end up with a buzz or rattle.
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
