Intro & Pet Barriers
Great site,
After years of bleeding Ford Blue, after all, I did work for them for 12+ years, I bought my first GM product last week. I'm the proud owner of a '05 Yukon Denali. As you already know, what a great machine!
Has anyone found a good pet barrier for tha back of the Yukon? I'm not a big fan of the type that "stretch" to the headliner to stay in place. We had that in our Expedition and it forever marred the headliner. Our son's Xterra has a great barrier that bolts in place and is very sturdy.........great accessory by Nissan.
As an aside, I have the 2nd row captain's chairs, so any pet barrier will have to also cover the "gap" between the rear seats. The 3rd row seats are out, to make room for Max (German Shepard), Maddie (Golden Retriever) & Melvin (Toy Poodle), although Mel usually helps navigate upfront.
Thanks,
Steve
I've been trying to find one that would work in an extended cab Sierra as well. Having Homer try and climb up to the front when driving is no fun.
Get one of those electric "invisible fence" doohickeys, and install it under the carpet...That dog will be cowering at the backglass in no time :D
