F/S JL stealth box 10w3v2
For Sale used sub and sub box from JL audio from my 02 silverado 2500HD, it was in my personal truck which has been cycled into in the company and replaced with an 05, it was used about 10 months, and i'll include the center console wich has to be modified making this a simple plug and play set up. for pictures shoot me and email, same goes for any questions -
i'm asking for 450 OBO it retails for just over 600 plus the console lid was around 150(charcole grey)
thanks James
Fits 1999-2002 Silverado Pickup with Center Console
If you drive a Chervrolet Silverado with front bucket seats, this Stealthbox® model was built for you. The compact subwoofer unit installs inside of the factory center console for a completely stock appearance and delivers intense bass output and quality from a downfiring 10-inch subwoofer.
The Hard Data:
Contains one 10W3v2-D2 in a downfiring, sealed enclosure. 300 watt power handling. Wired for 4? mono. Installs inside factory center console (not included). Cup-holders are unaffected. Console storage space is substantially reduced after installation. Rear A/C ducts must be removed in extended cab trucks. Permanent modification of the factory console is required. If the Stealthbox® is removed, the console cannot be easily re-installed. Will not fit GMC Yukon Denali, Cadillac Escalade or Cadillac Escalade EXT.
Model Name: SB-GM-SLVCNSL/10W3
SKU: 94098
Color: n/a (installs inside factory console)
Model years: 1999-2002
Match Grade: n/a (installs inside factory console)
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
    • Engine Wear and ISO 4406   1.) Cold Starts. 2.) High Particle Count. 3.) Low operating temperature viscosity and high low temperature cranking viscosity. 4.) Depleted AW, Friction and Acid packages.  5.) High engine load.    https://me.caltexlubricants.com/en_me/home/learning/from-chevron/heavy-duty-diesel-vehicles-and-equipment/The-Importance-of-Clean-Engine-Oil-and-Its-Impact-on-Equipment-and-Business-Performance.html   High particle counts have five sources. 1.) They are manufactured within the engine. Both wear debris and amalgamation of degradation products and combustion driven soot (worse in GDI). 2.) They are ingested via intake air. Ever hear the best oil filter is a good air filter? 3.) They are entrained in the fuel. 4.) This one is insidious. They are introduced in 'fresh oil'. 5.) They are introduced during the oil change.   ISO 4406 is the test that measures and quantifies the combine effects of all of the above particle related issues. You can mitigate your way into multiples of engine life by being attentive to them all.    https://www.hyprofiltration.com/blog/is-new-oil-clean   (from the link above)    [Quote] What Is the Recommended ISO 4406 Cleanliness Code for New Oil?   A good upper limit for new oil cleanliness is 16/14/11 (ISO 4406). Typical new oil usually has ISO codes of 19/17/15 or worse, which is far too dirty for sensitive components. This can be a major cause of degradation and premature failure. [Close quote].     Source of graph: Machinery Lubrication (GM Study)
