another dumb ?
I've noticed on my 04 ext cab 4x4 silverado that I need to clean the weather stripping around the doors quite often. Otherwise the truck sounds like its old when the frame flexes, esp pulling in and out of my driveway. I've been using armor-all, and when freshly done, the interior is dead quiet, but wears off quickly. Is there anything to put on the weather stripping to keep it conditioned for a long time? thanks.
I think the Armour All is what is causing the problem. Try mixing up a mild solution of dishwashing liquid in water, then lightly rub the weatherstripping that's squeaking with a paper towel that you've moistened with the mild dishwashing liquid solution. This should take the "oils" from the armour all off the surface of the weatherstripping and let it move quietly over the painted surfaces that mate up with it.
Might also be a good idea to de-oil (the same way) the painted surfaces that mate up with the weatherstripping.
i have the same problem, and i don't really think armor all helps very much. Shortly after I bought it i had it in to the dealer to complain about this and all they did was lube the weatherstripping. Whatever they used looked wetter and thicker and lasted longer, but don't really know that it solved the problem completely. Supposedly it's some kind of silicone lubricant.
I asked them to adjust the strikers/latches and they told me they couldn't do that. So who knows.
If anyone can figure out some way to actually solve this problem, i'll send a case of beer your way.
Did anybody actually try drying out their rubber by removing the oil altogether, as I suggested above??
Then you could join the majority of us who don't have the problem. What could be the difference? Could it be that we never armour-alled our weather stripping?
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
