Cool Math Trick
R Dogg 56
Use a calculator, you won't be able to do this one in your head
1. Key in the first three digits of your phone number (NOT the area code)
2. Multiply by 80
3. Add 1
4. Multiply by 250
5. Add the last 4 digits of your phone number
6. Add the last 4 digits of your phone number again
7. Subtract 250
8. Divide number by 2
Do you recognize the answer?
2. Multiply by 80
3. Add 1
4. Multiply by 250
7. Subtract 250
Dude, I don't swing that way, and I'm too smart for your silly reindeer games.
Quit asking for my phone number. :chevy:
I didn't come up with this. I got it from an Ebaumsworld and thought it was funny.
Wow, so many positive responses. Is everyone on this board always so pissed off?
It was a f**king joke. No need to get into a s**t-fit about it. Don't like it? THEN DON'T f**kING REPLY!!!!
How goddamn simple does it have to be for some of you? Jesus......
Dude, I don't swing that way, and I'm too smart for your silly reindeer games. Quit asking for my phone number. :fume:
I'm still not giving you my phone number man.
Man, I changed that sooooo long ago when you refused to quit calling me when you were drinking. :fume:
:confused:
Am I missing something here? Wingnut, what in the hell are you talking about? I didn't ask you for anything. Why would I need your phone number? I don't know you, nor do I care. I don't "swing that way" either, in case you or others need a reality check.
Silly reindeer games indeed.... :bs:
Well, I'm pretty much over with it, so it doesn't bother me anymore. Life is too short to argue about stupid stuff, especially on the Internet.
I guess I was showing my "intellectually challenged" side for a while there. I'm better now. :fume::confused:
No more attempts at humor for me! :fume:
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
