Vehicle Info
zimpher
Hey guys,
How do I find out info about an 02 Trailblazer I just purchased.
Any info would be appreciated.
VIN: 1GNDT13S922164079
Thank you for any help!
I can only access warranty history. Any maintenance work is only available at the maintaining dealer. Looks like it's really only had recalls done and one PCM reprogram.
This is kind of a mess because tables don't paste well, so I hope you can read it.
VIN : 1GNDT13S922164079
VEHICLE INFORMATION
Merchandising Model : CT15506 -2002 TRAILBLAZER LS 4WD Warranty Start Date : 09/24/2001
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : PREAKNESS CHEVROLET INC.
2317 HAMBURG TPKE
WAYNE , NJ 07470-6230
(973) 835-5050
Selling Source : 13 - CHEVROLET
Site Code : 02066
Business Associate Code : 111245
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 01065 TRANSMISSION TRANSFER CASE - REPROGRAM N/A Closed
RC 03012 TRANSMISSION SHIFT LOCK AND IGNITION KEY REMOVAL OVERRIDE COMPLIANCE N/A Closed
RC 03013 INSTRUMENT PANEL CLUSTER GAUGES INOPERATIVE N/A Closed
RC 04005 WINDSHIELD WIPER MOTOR FAILURE N/A Closed
YT 04032 SOFTWARE UPGRADE MAY BE NECESSARY. REFERENCE BULLETIN 01-06-04-052. N/A Closed
RC 04037 FRONT SEAT BELT RETRACTOR NONCOMPLIANCE N/A Closed
RC 04087 TAIL LAMPS/STOP LAMPS N/A Closed
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER 09/24/2001 126 miles 09/24/2004 36126 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH 09/24/2001 126 miles 09/24/2007 100126 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 09/24/2001 126 miles 09/24/2009 80126 miles
36/50000 CALIFORNIA EMISSIONS 09/24/2001 126 miles 09/24/2004 50126 miles
84/70000 CALIFORNIA SELECT COMPONENT 09/24/2001 126 miles 09/24/2008 70126 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
01/12/2005 147747 # V1265 - 04087 - INSPECT AND REPLACE ONE OR BOTH TAIL LAMP CIRCUIT 28164 miles
09/03/2004 119880 # V1115 - 04005 - INSPECT WSW MODULE AND INSTALL SEAL ASSEMBLY 23288 miles
09/03/2004 119880 # V1167 - 04037 - INSPECT SEAT BELT RETRACTORS, NO FUTHER ACTION REQ 23288 miles
07/05/2003 104604 # V0994 - 03012-INSTALL PLUG AND REMOVE OVERRIDE LEVER 13922 miles
07/05/2003 104604 # V0995 - 03013-REPROGRAM IP CLUSTER 13922 miles
06/17/2002 089683 # V0789 - 01065 - REPROGRAM ATCM 27684 miles
06/17/2002 089683 # J6355 - POWERTRAIN CONTROL MODULE TRANSMISSION REPROGRAMMING WITH 27684 miles
06/15/2001 023829 # Z6999 - PDI RELATED FLUID ADDS 2 miles
06/01/2001 A64079 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
© 1998-2005 General Motors Corporation. All Rights Reserved.
GM-Tech:
Thanks for the info, that was quick.
Could you give me the info as to what was originally packaged in the truck (optional equipment, etc)?
Thank you for any info!
Options are list two per line...
VEHICLE BUILD
Gross Vehicle Weight Rating : 2611 kg (5757 lb) Order Number : DFKG2K
Build Date : 06/01/2001 Build Plant : 12206
OPTION CODES
AJ1 - DEEP TINTED GLASS AJ7 - DR/PASS FRT & SIDE AIRBAGS
AM9 - SPLIT FOLDING REAR SEAT BACK AU0 - KEYLESS REMOTE DOOR LOCK AND TRUNK OPENER
AXP - MPV VIN IDENT POSITION A50 - FRONT RECLINING BUCKET SEATS WITH FLOOR CONSOLE
B30 - WHEELHOUSING & FLOOR CARPETING B32 - FRONT COLOR-KEYED FLOOR MATS
B33 - REAR COLOR KEYED FLOOR MATS B86 - MOLDING B/S COLOR
CJ3 - CLIMATE CONTROL C49 - ELECTRIC REAR WINDOW DEFOGGER
C5N - GVW RATING - 5750 LBS DAY - ASSEMBLY PLANT MORAINE, OHIO
DK2 - ELECTRIC OSRV MIRROR W/DEFOGGER EVA - EVAP EMISSION REQUIREMENT
GU6 - REAR AXLE 3.42 RATIO JF8 - BRAKE VAC POWER, 4 WHL DISC
KG4 - GENERATOR 150 AMP K34 - ELECTRONIC SPEED CONTROL WITH RESUME SPEED
LL8 - VORTEC 4200 SFI I6 M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
NC1 - CALIFORNIA EMISSIONS LEV NC7 - FEDERAL EMISSIONS OVERRIDE
NG1 - 50-STATE LOW EMISSION VEHICLE NP5 - LEATHER WRAPPED STEERING WHEEL
N40 - POWER STEERING N86 - FULL SIZE SPARE
QC4 - 16" ALUMINUM WHEEL QRF - P245/70R16 ALL-SEASON WOL
RYJ - RETRACTABLE CARGO AREA COVER R6M - NEW JERSEY COST SURCHARGE
R9U - PC CARBOOK ORDER SLM - STOCK ORDERS
TB4 - LIFTGATE T61 - DAYTIME RUNNING LIGHTS
T98 - STAMPING VEHICLE IDENT NUMBER UA6 - THEFT DETERRENT ALARM SYSTEM
UN0 - AM/FM STEREO W/CD PLAYER U73 - FIXED MAST ANTENNA
VXS - COMPLETE VEHICLE LABEL V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
X88 - CHEVROLET CONVERSION YD3 - BASE EQUIP FOR SCH GVW PL-FT AX
YD5 - BASE FRONT SPRING YD6 - BASE REAR SPRING
ZW7 - PREMIUM RIDE SUSPENSION ZY1 - SOLID PAINT
1SC - LS PREFERRED EQUIPMENT GROUP 3 * POWER HEATED MIRRORS * FLOOR MATS, FRONT & REAR * REAR WINDOW DEFOGGER * DEEP TINTED GLASS W/DEEP TINT REAR * CRUISE CONTROL * BODY SIDE MOLDING * LEATHER WRAPPED STEERING WHL * REAR RETRACTABLE COMPARTMENT SHADE * THEFT DETERRENT SYSTEM * REMOTE KEYLESS ENTRY 50U - SUMMIT WHITE
6DA - COMP FRT LH COMPUTER SEL SUSP 7CY - COMP FRT RH COMPUTER SEL SUSP
8DL - COMP RR LH COMPUTER SEL SUSP 9DK - COMP RR RH COMPUTER SEL SUSP
95D - MED PEWTER/DK PEWTER ACCENTS 95I - MED PEWTER/DK PEWTER INT TRIM
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
