Transmission Drain Plug
I have an 05 Silverado ECSB 5.3 w/ 4L60E tranny. I got to looking under it and there is no drain plug in the tranny. I thought there were drain plugs in all the NBS style trucks? What gives?
From what I understand, there is no longer a drain plug on the 4L60E. I recall from a previous thread someone ordering a new pan for a truck with the plug originally and the new pan did not have one. My dad's 99 has a plug, and I know this because I rounded it off (extremely common). Ended up dropping the pan with it full, very messy, but it happens.
By the way, where in WV are you?
It is a small world, I knew a guy that was in the Air Force with me that was from St. Albans.
B&M makes the drain plug kit. You can get a kit from Auto Zone. That is what they carry here in NC. Advance Auto also has drain plug kits.
It is a small world,I had to go to St.Albans this summer to C&O Motors for a dealer trade for a guys truck that works here in the body shop.
I'm originally from Summersville.
My parents and in-laws still live there, my brother and his wife live in Athens, but I'm in the Air Force and stationed in SC now. I miss the mountains.
That was me. The dealer (P&G Chevy / PartsZoneOnline) told me that GM had phased out the pan with the drain plug. The replacement has an indentation where the plug used to be, but no hole or bung. The pan that accomodates the plug is no longer available from GM.
When I ordered mine, I also ordered the plug, so I got my old one off (I had to drill out the center and weld an old wrench on it).
I'm crossing my fingers that the new plug will come out next time I change the tranny fluid - I used anti-sieze on the threads and washer. I think that not only the threads stick, but the washer somehow sticks to the plug and the pan - its a lot of surface area and its nearly impossible to break the seal. I believe that welding on it did a lot to loosen the gasket/washer.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
