04 4X4 TRANS TEMP
TEXCOASTIE
I HAVE AN O4 REGULAR CAB SHORT BED 4X4 HALF TON. I GOT AN AUTOMETER TRANS TEMP GAUGE FOR CHRISTMAS I WAS WONDERING IF THERE WAS A SENDING UNIT ON THE TRANS THAT I COULD TAP INTO AND RUN OT MY GAUGE SINCE EVERYONE IS GETTING A NEW CLUSTER AND REPROGRAMMINGTHE MILES AND THEIR TRANS TEMP IS WORKING THERE HAS TO BE A SENDING UNIT ON IT SOMEWHERE THANKS FOR ANY INFO :thumbs:
There's a thermistor inside the trans fluid pressure switch that provides a signal to the PCM. The PCM in turn provides a temperature message to the cluster over the class 2 data line.
I think somewhere there might be a chart that give the thermistor's resistance at various temp readings. The odds your gauge's input needs would match this exactly is doubtful, unless it was designed for that specific application.
I knew there was a chart for temp vs. resistance, but it's in a table format, so it'll take some work to understand this...
Transmission Fluid Temperature (TFT) Sensor Specifications
Temperature
Temperature
Minimum Resistance
Nominal Resistance
Maximum Resistance
Signal
°F
°C
ohms
ohms
ohms
Volts
-40
-40
90636
100707
110778
5.00
-22
-30
47416
52684
57952
4.78
-4
-20
25809
28677
31545
4.34
14
-10
14558
16176
17794
3.89
32
9423
10365
3.45
50
10
5104
5671
6238
3.01
68
20
3164
3515
3867
2.56
86
30
2013
2237
2461
1.80
104
40
1313
1459
1605
1.10
122
50
876
973
1070
3.25
140
60
600
667
734
2.88
158
70
420
467
514
2.56
176
80
299
332
365
2.24
194
90
217
241
265
1.70
212
100
159
177
195
1.42
230
110
119
132
145
1.15
248
120
89.9
99.9
109.9
0.87
266
130
69.1
76.8
84.5
0.60
284
140
53.8
59.8
65.8
0.32
302
150
42.5
47.2
51.9
0.00
