Tow Rating
BobG
Per this specs sheet on cars.com the GVWR is 5,150 lbs, the payload is 1,111 lbs, rear axle capacity is 2,900 lbs, rear spring rating is 2,700 lbs, max trailer weight is 5,200 lbs, and max GCWR is 9,500 lbs, along with a few other stats about the crew cab.
Ya gotta love being able to do "research" at work! :cheers:
Thanks for the info.  I'll check out cars.com.
Again thanks,
Bob
Bob,
Don't know if you caught this or not but to save you some trouble I linked the cars.com page where I found the specs on the crew cab S-10 above...just click where it says "this specs sheet on cars.com" in my above post...
But you probably already figured that out :cheers:
    • here is the high speed control wiring, i would also be checking  and cleaning ground connections high speed fan control.pdf
