MDT Key FOB Programming
wa3pnt
I have purchased an additional Remote Keyless Entry Key FOB for my 2005 Chevrolet C4500 Kodiak.
Both I and the local Chevrolet Dealer (not a Medium Duty Truck Dealer) have tried using the "normal" programming procedure where you HOLD the Unlock Button while cycling the ignition ON and OFF 2 times.
This procedure does not cause the C4500 to enter the LEARN Mode for the Remote Key FOB.
What is the Key FOB programming procedure for the 2005 Kodiak C4500?
George
___________________________________________
Usually on the road doing Rodeo Scoreboard & Sound
George
This is for a 3500HD. Looks like you may have to use a scan tool.
TRANSMITTER PROGRAMMING
IMPORTANT: Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect car.
There are 3 methods for programming transmitters, which are listed below as methods 1-3. Up to 4 transmitters may be programmed to the passenger door module (PDM). Each programmed transmitter is given a position of #1-#4 in the PDM memory.
Method 1 - No Tools Required, Program All Transmitters
IMPORTANT: All transmitters which are to be recognized by the PDM must be programmed in a single programming sequence. When using this program method, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter.
The order in which the transmitters are programmed will determine its numbering position within the PDM memory. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number stamped on the transmitter case is for reference only; #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available.
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds , the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to 4 transmitters.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
Operate the transmitter functions in order to verify correct system operation. Method 2 - Scan Tool Required, Program Individual Transmitter IMPORTANT: All transmitters which are to be recognized by the PDM must be programmed in a single programming sequence. When using this program method, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter. The order in which the transmitters are programmed will determine its numbering position within the PDM memory. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number stamped on the transmitter case is for reference only; #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available. Only use this option if you are certain which transmitter, #1-#4, is being replaced, or the new transmitter can be programmed into a previously unused position within the PDM memory.
Install a scan tool.
Turn the ignition ON, with the engine OFF.
Use the scan tool in order to access the passenger door module Special Function menu.
Select Program Individual Key Fob to program specific transmitters.
Follow the directions on the scan tool in order to program the transmitter or transmitters.
Operate the transmitter functions in order to verify correct system operation. Method 3 - Scan Tool Required, Program All Transmitters IMPORTANT: All transmitters which are to be recognized by the PDM must be programmed in a single programming sequence. When using this program method, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter. The order in which the transmitters are programmed will determine its numbering position within the PDM memory. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number stamped on the transmitter case is for reference only; #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available.
Select Program All Key Fobs to clear the PDM memory.
Follow the directions on the scan tool in order to program the transmitters.
