Pics online
Check em out guys.  Whatcha think?
Many more to follow, including transmission internals.
Whatcha think?
Im going blind  :D
Don't feel bad, Monday I sent an email with pictures of the tornado to a friend in Florida. Today I got a reply..... 'You forgot the pictures dumazz!'   :D
:D  Now there is something I hadn't thought of, a Transmission Lift!  I got the suspension lift, the body lift, and the natural progression is... Transmission lift!  :D
Just joshin, nice lookin truck!  Is that a stock skid plate, or did you fab that?   :D   :)
Stock plastic.  I saw a thread about it a couple of days ago, so I put it on the site incase anyone wondered what they were talking about.
I thought about being more specific with the tranny lift, but I got even funnier images in my mind the more I tried to explain.
EX.
70" lift
Hydraulic Transmission Lift  --(w/switches?)
Transmission Shop lift --(stilts???)
Mark have you changed out your fuel filter?  If so what part number by chance was it?  Just wondering cause i heard the GF626 is discntinued
They told me the GF481 is the correct one
That is correct.  I replaced my GF626 with a GF481.
I think the GM part # is 25055052.
Ok, I've peeked under my truck and located the fuel filter?  Anyone have pics/tips of the change?  Also, there's another "box" for lack of a better word that has a series of fuel or brake lines coming out of it.  What is that?  Abs module or something?
