Cold Air Intake
OK I've put a pencil to some numbers on what it would take to get your investment back on a cold Air Intake system.
If Gas is $2.59 a gallon (Current Price in CO)
And you spend 250 bucks on a CAI
And you currently average 15 MPG
15MPG 21Gallon Tank 315 Miles
16MPG 21Gallon Tank 336 Miles $3.62 Savings 70 Fillups or 23k Miles
17MPG 21Gallon Tank 357 Miles $7.25 Savings 35 Fillups or 12k Miles
18MPG 21Gallon Tank 378 Miles $10.87 Savings 23 Fillups or 8k Miles
And If you are reall lucky
19MPG 21Gallon Tank 399 Miles $14.50 Savings 17 Fillulps 0r 6,800 Miles
If Gas would Spike to $3.00 a Gallon (Not that far fetched)
16MPG $4.2 Savings 60 Fillups or 20K Miles
17MPG $8.4 Savings 30 Fillups or 10K Miles
18MPG $12.6 Savings 20 Fillups or 7500 Miles
19MPG $16.8 Savings 15 Fillups or 5900 Miles
So you can see you get the best bang for buck increasing to 17MPG and above that your advantage isn't as great. So if you can find something that get's you to 17MPG for cheap you will save considerably.
So if you Chip your truck and CAI and that gets you to a worst case average of 19MPG and gas is 3.00 it would take 12k miles to get your money back (aprox 1 year on average driving) That would assume that gas stays at 3.00 for a year.
What is everyones opinion?
:cheers::D
Sounds about right. Wich is why I haven't invested in one. Too much time to see a return. Hope the free one I won gives me some improvements in MPG.
I added a True Flow CAI unit primarily for a little more grunt while towing my 02 Yukon XL. I can feel the difference beginning around 2600 RPM on up and after 2 tanks, my mileage is up a little bettern than 1 MPG. I realize two tanks is not enough to get a good read. Howver, the unit looks really good under the hood and makes a little "intake music" at WOT.
I would strongly suggest to anyone looking into a CAI to look seriously at the True Flow unit.
:cheers:  :D
With your numbers that's to break even with what it cost to purchase it. After that your saving money. It also depends on how you drive. With better throttle response it's a lot easier to jump on the throttle from a start after you've installed it to negate any mpg gains at highway speeds.
:D  :chevy:
I disagree...The best "bang for the buck" would be keeping your foot out of it.
I got over 21 mpg in my '02 Z71 ex-cab...With the A/C on...By driving it at or below 65 mph on a road trip.
That's a great value because...Well...It's free. :chevy:
The advice I just gave you however, is not.
That'll be $3 from everybody that reads this post please...My truck only gets 93 octane and I'm almost out of gas money because my right foot has swollen to 42 pounds of pedal pushing podiatry. :cheers:
Oh...And I make this face a LOT. :fume:
Are you a sales rep for True Flow? Or just a happy true flow customer? I've seen in a couple of posts now about you raving how good true flow is. I like there products I know a lot of imports use Foam filters and a all metal tube is the best IMHO.
Anything has to be better then stock.
What is the reason for the design of the stock air tube?
I have an Air-Raid air-intake with a K&N cone air filter on my truck.
Can't say I noticed any difference in MPG.
Improvement in sound yes! ;)
:D  :chevy:
I'm getting about 17 mpg now with an '06 Z71 so there's not a lot of upside in replacing the intake, besides my truck is noisy enough. Thanks for the advice, though. I'll fax you the three bucks. :fume:
:D  :chevy:
$2.59/gallon sounds good to me right now, were up to $3.09 in CT! :cheers:
Just slowing down does the same thing and puts the money in your pocket. :seeya:
DEWFPO
I didn't buy my CAI for better MPG. I didn't buy my exhaust, headers, cam or custom tuning for better MPG either :seeya:
If you want better MPG leave it stock, drive like grandma (like mine at least) and keep your filters clean,and oils changed as necessary.
Personally I didn't buy a truck to worry about gas prices, even though they are thru the roof and rising.
    • Thanks @newdude, guess I'll keep looking.  Test driving so many trucks that have obvious things broken, I'm thinking "if they couldn't even be bothered to fix the power seat," what else is broken".   Just drove a 2021 where the power seat motor was grinding/binding and wouldn't do anything but make a terrible sound.   An owner that puts dents on the bumper, doesn't fix a seat motor, and had spotty service intervals (along with missing major services) doesn't give me the best of confidence.   Amazed at the number of people that will finance a $60k+ truck, run it into the ground, then trade with a loan balance (every single one had "loan/lien reported" on the CARFAX at the last year of registration).
    • Not true! I have been runing them since 2006 F250! suspension component that works as a sway bar, a traction bar, and a helper spring points directly to the RoadActive Suspension (RAS) kit. Works as a sway bar, a traction bar, and a helper spring.
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
