Six-8 bolts depending on bed length. Unplug wiring harness from bed(d/s rear) 3 screws holding filler neck and then lift that sucker up.
What he said... It's light so lifting it is pretty easy, I did mine alone and I arm wrestle again spagetti noodles...
... and lose. :banghead:
Dont forget the ground strap too....That thing can frustrate you if you forget it. :banghead:
Thanks guys. Look like I've found myself a project for this weekend. When the auto shop told me what they wanted to replace it, I almost sh** my pants. I must be in the wrong business!!!
And watch out if you have rustproofing - wear old clothes!
All the bolts are underneath mine, the bedliner made no difference for me. Alsp I don't remember taking the ground strap loose, there must have been enough slack.
Yeah, mine are all underneath too. Don't have the carriage bolts like the older trucks.
after the bed is slid back, will I need the "special" fuel line removal tool to take the fuel lines off of the pump?
Do you just tip the bed up on the driver side? My pump went too and dropping the tank seems like a pain. This iwll be a solo job!
Actually, my wife and I took the bed completely off and set it in the yard beside the truck. It really wasn't that heavy. I suppose you could tip it up on the driver's side or you could slide it back about 2 feet. It only took about an hour and 40 minutes to do. Wasn't bad at all.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
    • I'll bet your truck lost the bearings on a roller on 1 of the lifters, and now is wiping out a cam lobe.
