Mirror lED signals
Anyone know if you can put the mirror glass with the LED signals onto a truck which doesn't have them. If so how do you change the glass and is it prewired from the factory. Do you have to reprogramm the BCM also? I want to put them onto a 2002 Tahoe.
Thanks for any and all help
You can add them easily,The truck is not prewired but its not too bad to run the wiring thats needed,the hardest part is running the wires through the "boot" (The rubber thats between the door and the pillar post that has all the factory wiring in it)You also have to remove the door trim panels to run the wiring.
The BCM does not require reprogramming.
Check out this website....MUTH MIRROR They are the ones who supply GM with OE mirrors on the trucks.
